According to my information there are only three things that belt actuates. The only easy one to test is the power steering pump. You should be able to turn it by hand. If it turns, the issue is the cam shaft and that is a major repair.
Most people think you only need fuel, spark, and air to get start. Mostly true, but not entirely. You have all three and still no start. The only thing you may be missing is compression. If the vehicle has more than 75000 miles on it and has never had the timing belt replaced, you may have a belt breakage.slippage issue. Perform a compression check of the cylinders and is they any are low or they are not all approximately the same compression, you may need engine work. If the timing belt slipped or is broken, you may have additional engine damage to valves/pistons as this is an interference engine. Replacement of the water pump is recommended if timing belt is replaced.
Under the hood you should see a sticker that shows the belt routing. You will need a ratchet and appropriate socket the pull the automatic belt tensioner over to get the belt fully in place. It can be tight if you have big arms but it is not a big job. Start to finish anyone with the tools and strength to overcome the spring on the tensioner should be able to do it in half and hour. Probably less than half that time if all goes smoothly.
Sounds like a possible crankshaft position sensor. It is located behind the harmonic balancer, inside the timing cover. It sets by the timing belt, so if you have a loose timing belt it could hit the crank sensor or throw up pieces of itself onto the crank sensor. A bad crank sensor can mimic a fuel pump issue.
Hello dbhammons1 and thank you for asking your question here on fixya.com.
I have actually written a general information article that will walk you
through the general process of changing the fan belt on your 2002 Kia Sedona. It will also point you to the resources you need for
getting the diagrams of how the belt needs to go back on.
If this has helped you in any way, then feel free to follow my Twitter account for more great money saving tips and tricks. twitter.com/acoates23234
I follow back, too. :)
Seat belts are supposed to be under warranty for the life of the car, the exceptions being vandalism or abuse. Call your local Kia dealer, and ask them about this. Let me know how you make out, most dealers don't want to do a free fix, but they should. If they refuse to help, I will try to help further. Good luck!
is it a dealer only job or can you do it yourshelf
immo prob p1612 p1613 can i buy the parts i need
my kia sadona read code 0 but dose not turn on
need help
