Epson Stylus CX7800 All-In-One InkJet Printer Logo
A
Anonymous Posted on Feb 07, 2016
Why is my Epson Stylus Cx7800 leaving horizontal and vertical white lines when I copy a paper?
When I copy a drawing or something in black and white the printer is leaving horizontal and vertical white spaces in the drawing, how do I fix this problem. The pictures overall print is perfect not including these lines.
David Steeves
Level 1:
New Friend:
  • Contributor 57 Answers
  • Posted on Feb 08, 2016
David Steeves
Contributor
Level 1:
New Friend:
Answers
57
Questions
Helped
14572
Points
74
Change copy setting from normal to best as a work around
Printing lines
White lines appeared? In vertical or horizontal?
Vertically white lines : clog on head. Check nozzle & head cleaning.
Horizontal lines : error in linear encoder.
My Stylus CX7800 leaves horizontal lines across all my pictures
Common problem..
Check your settings for proper DPI (dots per inch) and also change the ink cartridge.. ensure it is cleaned and calibrated as well..
2answers
I get a thick vertical black line/margin down the entire page when i scan on my SX115
Please make sure the scanner flatbed is clean.
You can also try to copy and see if it happens on copying.
If it does, then your printer needs servicing.
Change black ink and now prints with white lines through the words on every other line
It is CLOGGED print-heads that cause the ink to _not_ be sprayed onto the paper, resulting in "white" horizontal lines.
Run a "print-head-cleaning-cycle", using the Epson software installed when you installed the printer.
2answers
What can i do if i lost my install cd for my epson stylus cx7800
Just go to Epson's website and you could download a copy of the drivers, and any other software that was on the cd.
1helpful
Horzontal white lines cut through print and picture copies. When doing head allignment the horozontal bars all have a white gap, 1 through 7. Epson Stylus CX5400
You don't need to do head alignment, because it is for vertical banding in printout. Vertical banding can be minimized by disabling high speed option without doing head alignment. If your printout have horizontal white lines, do check nozzle and head cleaning, or you can minimize white lines by printing in best quality (photo).
2helpful
Epson Stylus r220 prints with white lines... i installed a CIS and it worked fine for about 6 months, now i'm getting prints with white lines (or fine spots) i tried nozzle check, which comes out good......
Nozzle check must perfect for perfect output. There are tranversal lines at vertical straight lines that represent same point of head micro piezo. If tranversal lines no clog at all, but vertical straight lines not perfectly straight, the result not good (like horizontal white banding). Check it? Head aligment is for vertical banding. If your result is horizontal banding, you don't need to realign head. It's caused by some residual at the output of head sprayer. So, the spray of ink not straight to paper. Try to print with photo/best photo.
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
