see this causes and fix it. God bless you
POWER/CANCEL press for to cancel the error codes.
First to unlock depending on model. There will be a pull tab either
under the lower kick panel, behind the filter cover, or under the top
panel. Pull this tab to unlock the door. Now you can remove the clothes
and water. Refer to the owners manual for the location of your emergency
door pull tab.
Door Switch
You will need to
remove the door switch
to check it. You will perform an ohm reading on the bottom terminals.
The reading varies from manufacturers most Frigidaires is around 1500
ohms others like the whirlpool duet is checked at the main control board
with the door closed should be around zero ohms. You will need to refer
to the tech sheet or service manual for the proper reading.
Main Control Module / CCU
The main control unit is the circuit board located behind the console.
If the door switch tests good the main control is usually the problem.
Check all connections for a goood tight fit. You will need to refer to
the tech sheet or service manual to check this further. The main control is easy to replace.
Power Cord
If the washer won't start, check to be sure
there is power to the electrical outlet for the home. If that is OK, the
power cord itself might be defective. This is rare. You can check the
power cord with an Ohm meter for continuity.+fuse thermal +c.breaker
