Precor TRM 833 Treadmill - P30 Console Logo
A
Anonymous Posted on Feb 06, 2016
I moved treadmill to another location and all lights up but when I click start it counts down 3, 2, 1 and then nothing. The tread does not start. Any thoughts on what might be wrong?
greg kinsley
Level 2:
Novelist:
  • Expert 145 Answers
  • Posted on Feb 10, 2016
greg kinsley
Expert
Level 2:
Novelist:
Answers
145
Questions
0
Helped
83165
Points
273
Hi There, usually when we move fitness equipment we tend to pull cables loose a bit here or there. Please recheck your connections and if you have troubles you can always email gregATbuyfitnessrepairpartsDOTcom for more help. Good Luck!!
Does anybody know what a bar that looks like its loading on the bottom of the screen ans nothing works means on my x7i?
Reset the machine with the small button to the side of the power button, and disconnect the machine power cord by 2 minute and toucht the small swithc with the eraser pencil make click.
Now try again. However if the problem persist try this:
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
God bless you
Can you advise please
reset the machine make this: God bless you
    • 3
    • 4
    • 2
Can not calibrate a true 850 ztx treadmill. has error code E5:sensor. aborts calibration saying no speed sensor. is the speed sensor located within the main motor? What lights should be seen on the...
However reset the treadmill
    • 1
    • 3
    • 4
    • 2
My facebook, firefox. youtube all are not loading correctly. the script is on the left side of page with nothing in middle. Has little links and blocks all crowded to gether and everything is messed up....
RESET THE machine, follow this steps and fix it. God bless you
      • 3
      • 4
      • 2
    Nordic track A2350 treadmill, I found this unit with lights blinking this afternoon, so I unplugged for 1hr and when plugged back in the only thing that happens is the red iFit logo comes on. What can I...
    reset the treadmills, follow the steps and fix it.
    God bless you
      • 1
      • 3
      • 4
      • 2
    Norditrack a2550 model stopped working while I was on it. The control panel will beep then light up like a Christmas tree but just goes into a nonperforming demo mode. Treadmill wont work! Help
    1.
      • 1
      • 3
      • 4
      • 2
    1helpful
    Tread is sliding and rubbing agianst right side of track.
    Make sure treadmill is running when you adjust belt. The treadmill belt tracks as the belt goes around. I usually put machine on 2-2.5 if belt is not rubbing instantly. If belt is already against plastic, turn adj. counterclockwise on the opposite side about one full turn. You can usually move belt with your foot to see if it aligns any with turning on the treadmill. Once belt is not rubbing, turn treadmill on and continue alighing the belt.
    Your Problem: jazfit-750 Treadmill motor will not turn on
    DEAR
    AT FIRST YOUR MOTOR CONTROL BOARD IS DAMAGE
    I can turn it by hand it turns smoothly and the tread moves fine and the belt from the motor to the tread is good
    Top Precor Exercise & Fitness Experts
    Sportsmith LLC
    Sportsmith LLC
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
