The Flexx10 has a micro SD slot, the SD card is about the size of your finger nail. If your Android phone also has a micro SD card you just remove it from the phone and plug it into the Flexx10. Then just transfer the pictures from the SD card to the tablets internal hard drive. When complete put the SD card back in the phone. If the SD card in your phone is the standard size it obviously won't fit the Flexx10. You then have the choice of either using Bluetooth to transfer the pictures between devices or buying a USB SD Card converter and plugging that in your FLexx10 with the Android SD card mounted in the converter.
SOURCE: micro sd card in sim card slot removal
I just did the same thing. I didn't want to put anything metal in to the slot. After trying with various pieces of hard packaging plastic I put double sided sticky tape on a piece of plastic and slid it down into the slot. The sd card attached itself to the sticky tape and I was able to pull it out. Good luck
Was the SD card used by another computer/camera/device? You may have to format it Use Fat32
SOURCE: how to reinstall android 4.2.2 jelly bean in nextbook 8
You could download a JB rom for your nextbook 8 and flash it using live suit or do a factory reset by turning it off then hold down the vol up button then hold the power at the same time until you get recovery appear then you can do a factory reset.
Testimonial: "I have tried the factory reset with power/volume button. First screen is NO COMMAND hit up volume did reset and same. where is reset button on back. Only have speaker holes."
SOURCE: SD card wont mount or let me download to it on Android Zeepad 7DRK
Try inserting the memory card into a card reader and connecting to a computer and copy files to it to see if it protected
SOURCE: put my apps on my sd card
Go to applications section under settings and click on the one you want and it should open up and there is a button transfer to sd card.
