Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television Logo
m
mable collins Posted on Feb 05, 2016
When I try to turn on the tv the power lights up then gos off in about 2-3 seconds.and wont turn on
1 Related Answer
Anonymous
  • 62 Answers
  • Posted on Sep 06, 2012
SOURCE: tv wont power up?
could be buttons,unplug them and try remote, or the convergence ics are bad
http://www.shopjimmy.com/
1helpful
Dell Inspiron 1100 won't turn on
unplug, take out battery then hold power button for 30 seconds then plug back in and turn on
if the3 laptap gos on without the battery you need a new battery
Tv turns on then powers down
Try doing a factory reset. Here is a link to the manual in case you don't have one. Hope it helps. http://www.manualowl.com/m/Polaroid/TDA-03211C/Manual/230758
3ds wont turn on
Try holding down the power button for a minute and this should turn it off so the blue light gos off, then you can press the button again it should come on properly.
My tv wont turn on the green light flashes than gos red
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement. Hope this will help to solve the problem...
Turned off with out doing anything
if it is a red light.... you have the ps3 equivalent to the rings of death on a xbox 360 meaning it had a serious system crash it has something to do with the gpu and cpu and you must send it back for a replacement as it is unfixable, here what the colors mean, red=dead, green=good, yellow=overheated
Sony BRAVIA 32 inch
I had the same problem with a old Sony TV.
To find out if the problem is temporary
  1. Turn off the television.
IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
2. Unplug the television power cord from the electrical outlet.
3. Let the television remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet.
NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
5. Turn on the television.
If the light is still flashing the tv has stop working and you will need to buy a new one.
3answers
Tv wont power up makes a noise but no picture
Your power transformer is likely shot. It'll cost at least $200 to have it replaced. Someone can come to your house to diagnose it. Usually costs around $65.
1helpful
3answers
Samsung LTN226W 22 in....
I'll go through the basics that you can try yourself. It might be a problem with the backlighting, which usualy is very cheap to fix - take a flash light, dim the lights in the room and flash the light into the screen to see if theres any picture visible. If so then you're looking at a backlight or backlight inverter failure, like I said, cheap. second(or first) thing to try is changing the cables you have the TV connected with, they might not be seated well, or have some other problem. For a tutorial on changing the inverter click here: http://www.lcdpart.com/doc/inverter_installation.html BUT - have a warranty? don't touch it and take it back to the shop. Good luck
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
