Just replaced the ink cartridges
Switch on the printer. Halt a minute until the device is idle. Unplug the USB cable from the printer's rear. Look at the connection method. In case it is wireless, examine whether the printer is linked to a wireless network. Take out the ink cartridges from the printer. With the printer switched on, unplug the power cable from the printer's rear and wall socket. Wait a second and then connect the cable back to the printer. Now, examine whether the issue persists. In case it exists, upgrade the printer 's firmware to the recent version.
123 hp com Quick HP Printers Setup Easy Installation Guidelines
SOURCE: error 0xc18a0106 and I've followed
Hi gave it a go
I found this I know your error not in here but it may work for
It worth a try nothing to lose and it may work.
I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it
Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: Ink System Failure_ Error 0xc18a0106
Hi
Reset the product:
5. Wait 60 seconds.
SOURCE: have a hp 3310 it says ink system failure error
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, press the on button, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't clear the error then you may need to re-prime ink through the system to clear the error. There are good instructions for doing this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
SOURCE: Error 0xc18a0106
This is most common error in inkjet HP inkjet printers.But you are not mentioned model number, any how try this:
Step 1.
> Remove all the supplies like print heads & cartridges..
> Remove USB or any other device connectivity from system.
> Switch off the printer.
> Wait couple of minutes.
> Switch on the printer, wait till printer asked for the supplies.
> Insert supplies as per specified messages.
> Check for ready mode, insert data cable & give print command.
>>>Check.. no message.. END.
Step 2:
> If problem remain same..(I will suggest for tech guys)
> switch off the machine, remove all the supplies
> Open printer side covers.
> find out the CMOS batter mounted on formatter ,remove it..
> wait couple of minutes..
> with out CMOS batter do the above said step 1 process.
> check.. I hope it will resolve this issue..give print command.. verify..once its resolved CMOS batter has to be installed.
> Switch off the machine,
> insert CMOS battery,
> do again step1 process,,..
......END....
Best of luck...Thanks for choosing FIXYA
SOURCE: Error: 0xc18a0106
Where is the ok,cancel,black and color button on the priter
Hp photosmart D7160
