Question about AT&T ATT-974 Corded Phone
Phantom intercom rings to one phone.
Extension 11 - which is supposed to be the main line - receives intercom rings from various extensions without the extension initiating them.
2 Suggested Answers
SOURCE:
SOURCE: Intercom / page problem with AT&T phones model 944 and 955
I have the same setup in a small office I consult for and I found the intercom problem to be caused by the DSL filters. It seems the DSL filters also filter out the frequency that the phones use to communicate with each other. If any of the phones had a DSL filter on them the intercom and hold button would not work properly with the other phones in the system without filters. Once I took the filters off the intercom and Hold function worked fine.
Posted on May 05, 2010
How do I reprogram the phone to ring when a new call comes in, default to a certain line, and show caller id when a call comes in.
The answer to the Caller ID question:
Depend on the type of system that the phone is connected to. Late model Partner ACS equipment will display Caller ID info between the first and second rings, provided that the telephone line is plugged into a module that supports Caller ID.
The answers for the other 2 questions are taken directly out of the Partner ACS Programming Guide which is available for free download at Avaya's website.
Ther answer to the incoming call line ringing question:
Again, depends on the system. For the Partner ACS:
1) Press FEATURE 00 at extension 10 or 11.
2) Enter the number of the extension to be programmed for Line Ringing.
The green lights next to the line or pool buttons show the current Line Ringing settings for all
lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
light next to that button is off.) The following ringing options can be shown by the green light
next to the line or pool button:
? Immediate Ring - on steady
? Delayed Ring - flashes slowly
? No Ring - flutters quickly
3) Press the line or pool button until the button light shows the correct setting (the setting for the
currently selected line or pool also appears on the display).
4) Continue programming, or exit programming mode.
Line selection:
For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing calls....again....it depends on the system. For the Partner ACS:
1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
2) Enter the number of the extension to be programmed for Automatic Line Selection.
3) Press **.
4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
Line Selection
depend upon the type of extension:
? Key Extension: Outside system lines, Left Intercom (the factory setting)
? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
setting), Pools 881-883, individual lines
For each button pressed, a display similar to the following appears:
5) To exit Automatic Line Selection, press **.
6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
Jan 06, 2011 | Lucent 18D Corded Phone
How do i set the intercome on a speakerphone 944
Assign an Extension Number to Your Phone
1 Press program.
2 Press down arrow until the screen displays EXTENSION NO, then press right arrow.
3 Press the up arrow or the down arrow to select the desired extension number (from 11 to 22).
4 Press save store your selection.
NOTE: If you duplicate an extension number, you will hear a repeating
short ring. Repeat Steps 1-4 and assign a different number (from 11 to 22).
Oct 06, 2010 | AT&T 944 Four Line Intercom Phone
Line is on "no lines rings"
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Central telephone Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
Sep 22, 2010 | Lucent PARTNER18 Corded Phone
I work for a small non-profit organization and we have a Lucent phone system - the problem is that when ANY call comes in on the mail line - it rings on everyone's phone. How can I fix this so that it...
Press the right hand intercom once. The display should say Centralized Programming2_bing.gif.
Dec 18, 2009 | Lucent PARTNER18 Corded Phone
Privacy
Unfortunately you cannot toggle this feature.
On extension 10 or 11
Feature 00
Left Intercom, Left Intercom, Right Intercom
Enter extension number that you don't want to ring
hit the line key until display shows No ring
To do next extension : Right Intercom and enter next extension number.
Follow same procedure for all extensions.
Feature 00 to exit programming
Let us know if you need additional assistance.
Cheers
Jul 16, 2009 | Avaya Eurostyle 18D Corded Phone
Phone not ringing
This feature has to be enabled on extension 10 or 11
Press Feature 00, left intercom, left intercom, right intercom
enter your extension number
press line button until it is in the solid state and display say immidiate.
Press Feature 00 to exit programming.
Cheers
Jul 09, 2009 | AT&T Lucent MLS-12D Phone
Lucent Partner 18D phone not ringing.
Press Feature 00
Input your first extension that you want to ring.
Press desired line to ring until display say Immideate.
Press Right Intercom for next Extension.
Cheers.
May 19, 2009 | Lucent PARTNER18 Corded Phone
I need to silence an extension on the lucent 18d telephone
From ext. 10 or 11, press Feature 00, left intercom (twice), right intercom (once), Dial ext. number of boss' phone. Lights on the line button will indicate ringing state for that line:
Green light - Immediate ring
Fast Flutter Green light - No ring
Slow Flashing Green light - Delayed ring
Press each line key until Fast Flutter Green light appears.
Jan 05, 2009 | Lucent PARTNER18 Corded Phone
Phone ringing.
On extension 10 or 11 press Feature 00
Left intercom, left intercom, right intercom
Enter your extension number
Press line buttons until its a fast blink and display say no ring
Feature 00
only transfered calls will ring
Nov 21, 2008 | AT&T Partner 18 Phone (315805B)
Lucent Partner 18D - stop ringing of line 2 at phone
From extension 10 or 11
Press feature 00
Left intercom
Left intercom
right intercom
all lines that are programmed on your phone will light up.
Solid means immediate ring. Slow flash means delayed ring. Really fast flash means no ring.
Press the line you wish to not ring, 2 times.
Feature 00 when you are done.
Oct 14, 2008 | Lucent PARTNER18 Corded Phone
AT&T ATT-974 Corded Phone Logo
52 people viewed this question
Top AT&T Lands Phones Experts
Marvin
Marvin
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
