Question about HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer blank pages after attempting to print second envelope from same document - turning off and back on solves temporarily
Starts printing blank pages after attempting to print second envelope from same document - turning off and back on solves temporarily. Has also happened with Laserjet Pro 400 color M451dn
  • Steve
    Steve Aug 30, 2016
    Not using mail merge - simply modifying document with a different address. Only happening with this printer since it is the only one I use for envelopes.
    Sergeant:
  • 360 Answers
If the same fault occurs with different printers it is almost certainly caused by the document.
"...second envelope from same document" suggests you are using a mail-merger. Is that right?
What happens if you start again from scratch? Mke a new document and try to print it a a single entity, without using mail merge?
Posted on Aug 29, 2016
Testimonial: "Not using mail merge - simply modifying document with a different address. Only happening with this printer since it is the only one I use for envelopes."
  • Robbie Goodwin Aug 31, 2016
    If that's the only printer you use for envelopes, what was the bit about Laserjet Pro 400, please?
    What happens if the document is closed and a fresh document created for the next print?
    If that makes no difference, what happens if the application is relaunched and then a fresh document created?
    If that makes no difference, what happens if the system is restarted and then a fresh document created?
SOURCE:
  • 30 Answers
SOURCE: HP LaserJet 1020 Prints a Black Line when at the right side when using Ms Word 2007
First, you need to try update the latest microsoft office patch file from microsoft or you can open the MS Word, go to "HELP" menu select the update MS Word or related. Try the latest patch file first. You also can try windows update and select custom update, see their list have this problem solution or not. Second, you need to go to HP website download latest driver for LJ1020 and suitable use on Vista. Lastly, if still not solve the problem, you need this problem/issue to microsoft, ask their solutions. Kent
Posted on Aug 23, 2007
jaylex
  • 417 Answers
SOURCE: HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Posted on Jan 28, 2008
SOURCE: HP Laserjet 1020 - prints blank documents
in my printer the resistor R348 on the motherboard printer was broken. The value that must have is 10 ohms. I have changed and the printer has resumed work.
Posted on Dec 07, 2008
Evildice
  • 222 Answers
SOURCE: hp laserjet 1320 printing blank pages
check printer door, there is a small plastic piece wich pushed down (to open) lasser scaner cover. if this piece is broken you can get blank page
Posted on Sep 24, 2009
SOURCE: Using hp laserjet p3005n, when I print one page it sends blank pg
Annoying but easy to solve.
Go to the printer's ip address management page from a web browser. Look under the TCP/IP address settings. Click on the advanced selection. Disable the LPD Banner page. That should fix it, if it's not under advanced poke around until you find LPD Banner Page. ;)
Posted on Oct 08, 2010
I have a hp 1320 laseret printer.when I order to print. this printer prints two pages. I could not solve this problem. would you please help me?
What document you are trying to print?
If it is Excel or Word document you have created a second blank page, reopen the document and delete the second empty page.
Nov 17, 2014 | HP LaserJet 1320 Printer
When asked to print my c5180 all in one ejects blank sheet of paper making no attempt to print
Just click below for more information;
s.gif » Macintosh: All-in-One Ejects Blank Page or Pages in Mac OS X V10.4
Mac OS X V10.4: A blank page or pages emerge from the product when it is turned on. s.gif » A Blank Page Prints at the Beginning of Every Print Job ...
A blank sheet of paper prints at the start of every print job. s.gif » Load Paper
Instructions on loading paper and envelopes. s.gif » When I Try Printing in Windows Vista, My Printer Is Not Available in the List of Printers ...
Windows Vista: The product does not appear in the printers folder when attempting to print on a network. s.gif » HP Photosmart C5180 All-in-One Printer: Manuals
... HP Customer Care | HP Photosmart C5180 All-in-One Printer | Product information HP Photosmart ... One Printer | Product information HP Photosmart C5180 All-in-One Printer: Manuals About these files: These
Hope this may help;
Regards,
VOTIT
Aug 23, 2008 | HP Office Equipment & Supplies
My HP laserjet 3050 when i copy a page the paper prints black
Symptom: Black or Blank image while copying or scanning.
Part suspect rating: Scan head..70%
Scan head cable...25%
Formatter...5%
For tech guys only: Remove ADF unit from the printer, remove both side covers of adf, remove & replace scan head, check...
Replace scan head
Jul 21, 2012 | HP LaserJet 3050 All-In-One Printer
49 error on HP laserjet 3050
Internal Embedded Software Error. Manual says to power off for 30 seconds. Power it on and let it initialize. If the error persists you will need a tech.
Aug 15, 2011 | HP LaserJet 3050 All-In-One Printer
I am getting a blank stripe top to bottom on every printed page
You write "I am getting a blank stripe top to bottom on every printed page". You didn't say copy or scanned pages. Change the toner cartridge.
Feb 04, 2011 | HP LaserJet 3050 All-In-One Printer
HP Color LaserJet CM2320nf MFP Envelope wrinkles
On alot of printers when you print envelopes theres a back door on the printer to prevent the curling or wrinkles. Just open the back door when doing envelopes.
Best of luck and have a happy and safe 4th of July weekend!
Jul 02, 2010 | HP Office Equipment & Supplies
My HP Laserjet 3050 frequently pauses when I try to print something like a PDF image. Other times, it just won't print it.
A PDF file is a "complicated" document, containing lots of "put some text starting at (X,Y) using font Z at W pixels high".
So, the software inside the printer takes some time for the printer's CPU to "compose" a complete page.
Apr 10, 2010 | HP LaserJet 3050 All-In-One Printer
HP Laserjet 3050 blank print
Have you tried a new toner cartridge? Usually blank pages are due to a missing bias voltage to, or in the cartridge.
Aug 11, 2008 | HP LaserJet 3050 All-In-One Printer
Hp laserjet 1300 prints extra blank page
did you try the hp laserjetIII driver
Apr 22, 2008 | HP LaserJet 1300 Printer
HP LaserJet 3050 All-In-One Printer Logo
268 people viewed this question
Clive
Clive
Thomas F. Schneider
