I want to transfer some calls to my mobile phone when I am out of office. we are using KX-T7730 phone and KX-TES824. I did the configuration in my extension using 713+0+my cellphone+#. In KX-T7730, I did the configuration as below: 1. Program + *#1234 2. 607 ,set up all the jack no enable 3. Program exit. The light of button FWD/DND still is off After test,the call cannot be transferred to my cellphone. I have another question, how to check the extension number for each Jack (No.)? Could you please help me ?
SOURCE: automatic transfer to a mobile phone number
This question came up before and it works if you have a TA-824 as the system. http://www.fixya.com/support/t3120724-forward_calls_outside_number
The key is that you go to the intercom and dial 9 to get an outside line. If you get a line, you don't have to program 400 to disable the unused lines. After that, you enable outside line transfer, change the time for longer than 10 minutes if you need to, and dial the 7139 phone number # forwarding code.
Hope this helps. If you're using a different system and it doesn't, post back as a comment with your phone system model number.
Carl
SOURCE: I have followed the instructions
Did you use the *7102/3/4/5 code? There is forward inside, outside, or both. The *710x forwards both.
Carl
SOURCE: I have Panasonic KX-T7420s with a TVS50. I have
Take a look at the manual. One of the bits in programming deals with the status of the FWD/DND button. You can make it light solid for FWD and flash for DND. There are other ways to intercept the calls, but trust me, this is the cleanest. You set 7104 165 # and it will forward always on no answer after x rings. Those rings are set system wide and can be adjusted in programming.
If you sit down wiht the PG manual, pay attentiion to programs 202,203,619 and 990 area 9 bits 3&4. A ring cycle is about 6 seconds and the default intercept is TWELVE rings....you should adjust that to no more that 4.
Car
SOURCE: how to assign password for the extension not to make international calls
It's not a password, it's a restriction. You change the Class of Service for the phone and put in the international code as a restricted digit.
Check your Programming manual for the system.
Carl
