My cell phone stopped charging
SOURCE: MY I9 cell phone doesn't wanna to charge
I had this problem. I replaced the provided wall usb charger. (I kept the cable and replaced the device you plug in the wall, you can get it as an ipod accesory in most stores.)
SOURCE: sgh p310 wont charge
Hi!
Please check your charging port if the pins are still OK. Please also try a new charger. Perhaps your charger is already defective.
Have fun!
*Your vote is highly appreciated. Thanks in advance!
SOURCE: my juke phone wont charge help
Either the charger is not working or you got a bad plug inside the phone I would take this to a verizon dealer and have them try some things with it. If this phone has a contract to it I know verizon would repair or replace this phone.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: samsung D900 wont charge or switch on..
your phone hardware might be dead , there is no way u can start it , u need to go for a service of your phone and they will flash the entire hardware and reinstall the software
SOURCE: razor cell phone wont charge
steps... 1) check by using another charger...if it gets charged then change ur charger.. 2)if its not getting charge then replace the battery and then try charging...if its again not working then battery problem..change it 3)if the battery s in proper condition then the problem s with the phone charging socket..change it for cost!!!!!!!!
