I need to purchase two set screws so I can attach a Gatco Tiara Robe Hook
I suggest you take the robe hook to your local hardware store and ask your question again.
The term "setscrew" is a description of a type of bolt that is threaded all the way to the head. Using unfamiliar terminology can produce misunderstandings so it is better you show the item to an experienced person.
2. If you have a tape measure, just measure between the screws making sure you are in the center of each hole. That will be the width you will put the holes in your bathroom wall.
***WARNING*** IF YOU ARE WANTING TO PLACE ON A TILE WALL, YOU MUST HAVE A CERTAIN TYPE OF DRILL BIT.***
