Engine brake?
no Vitara has such a feature or part.
post a real question, job, or a symptom.?
post the context of the topic,?
or post a photo with finger pointing to the object.
brake.
No Jake brakes on Vits. even with diesels.
my guess, you read the words in the oper guide
a rare thing here.
"natural engine braking occurs when...)"
that?
here read the wiki, its all there.
https://en.wikipedia.org/wiki/Engine_braking
Engine brakes or Jacobs brake on diesel engines work by using engine oil pressure controlled by a electric solenoid in three stages, the oil pressure is directed to a piston which holds down an exhaust valve slightly approx 2.85-3.5mm.
The three stages of exhaust brake on a six cilinder engine activates two cylinders at a time, cylinders 1-2 stage one, cylinders 1-2-3-4 stage two, and 1-2-3-4-5-6 stage three.
A Volvo engine brass or VEB works kind of the same only it uses a separate lobe on the camshaft to open the valve for engine braking...
Hope this helps..
