Cell Phones Logo
E
Erica Posted on Feb 04, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Stuck in reboot loop. Help - Cell Phones
Iron
Level 3:
  • Master 3,018 Answers
  • Posted on Feb 04, 2016
Iron
Master
Level 3:
Answers
3018
Questions
Helped
1670474
Points
10301
If you're in a boot loop you will need to factory reset or have it warrantied out. No other options.
Acer aspire is stuck in repair loop
From cold start, try F8 and if granted a choice to load as normal, choose that. If normal load succeeds, after Windows finishes loading, restart the computer. This should store a normal registry, i. e. one that does not direct you into a loop. I probably would subsequently use an sfc command but to avoid describing that I would simply suggest downloading Glary Utilities and going to the system repair menu item that will replace/repair system files. That takes a long time but then you know your system files are not corrupted. And I would reboot again, then.
But for you, here is a link that describes how to free yourself out of the endless loop if the above is of no help:
Windows 7 help and support forum
Nordic track x91 stuck in ifit live loop
Check this link out, there's some useful information that could solve your problem if you're still dealing with this loop.
best of luck!
https://thatguyreviews.com/treadmill-display-rebooting-ifit/
My computer keeps rebooting
Does it Boot or is it stuck in a boot loop cycle? Have you done ANY hardware or software, new OS?, updates/upgrades lately? Memory? Put in a new CMOS battery. Try reseating Memory Mods. Are the Fans, heatsink, vents clean? Open the BIOS setup, check Clock, set if necessary, Disable Auto Reboot. Remove ALL Media DVD,CD,USB devices, Printer cable, ect., Will it boot to Safe Mode? Take a look : http://searchenterprisedesktop.techtarget.com/Steps-for-solving-the-reboot-loop-problem May be a bad HDD? Remove and test, replace if necessary.
HP mediasmart EX470
Hello it depends on your current operating system.This could have happend after the update from MS yesterday.
It looks like a failed update.
Here is a link if you are running server 2008:
http://serverfault.com/questions/362759/server-2008-stuck-in-reboot-loop-configuring-updates-stage-3-of-3
Good luck
Stuck in the dry cycle
defect in main panel .....call for service ...
Jul 25, 2009 • Dishwashers
Hard drive won't reboot. Stuck in a loop.
start the machine press f-8 select "safe mode" press enter run chkdisk/r
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
