Question edited for clarity.
Question moved from Misc Category.
F01 is a very straight forward error and it means that your dryer has detected a short in the main relay power control board mounted to the left side wall under the top panel of the dryer. Oct 19, 2018
F01 means that the main relay control board inside your control panel has failed and your control board would need to be replaced to fix the issue.
Apr. 18, 2014
The F01 error code usually means the main electronic control board has failed and will need to be replaced. Sometimes it can be just the thermal fuse causing the error but in most cases it's going to be the control board. If you need more help you can visit the link below and get troubleshooting advice. Whirlpool Duet Dryer F01 Error
The F01 error code indicates a failed primary electronic machine control board. This can be caused by a glitch or power surge through the power lines. Try unplugging the dryer for 5 minutes and see if the code clears. If it doesn't, then you will have to replace the electronic machine control board,
