Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts. ..
GE Universal Remote Codes ' Jasco
https://jascoproducts.com/support/ge-universal-remote-codes
A version 2 through version 4 remote will have a "V2" to "V4" after the model number. ... Program your GE Universal Remote using the correct code list and ...
GE Universal Remote Codes and Instructions ' direcTutor
www.directutor.com/content/ge-universal-remote-instructions
Direct Code Entry for GE remotes with 4 digit codes. 1. ... Press and release the button for the device you are programming (TV, VCR, DVD, etc.). For AUX, press ...
How to Program a Universal Remote - Frontier
internet.frontier.com/resources/how-to/program-a-universal-remote/
Here's how to program universal remotes from RCA and GE: ... with whatever device you're currently attempting to program (i.e. the TV, the DVD player, etc.) ... If you havea V2, V3 or V4 remote and are programming a DVD player, press PLAY ...
How To Program A GE Universal Remote ' Codes For ...
codesforuniversalremotes.com/program-ge-universal-remote/
The flashing blue light shows that the TV is receiving I.R. from the remote but doesn't mean that the signal being received is recognized by the Samsung. If you have a "universal" remote then your TV code may need to be re-entered/reprogrammed...changing batteries in a "universal" will usually require it to be reprogrammed. Also...because of the remotes construction (rubber membranes with carbon dots that short across PC traces) I've seen certain buttons stop working altogether.
