Top half of tv is white it started with just a line from side to side and has become worst
  • Televison & ... Master
  • 3,604 Answers
Restore Disappeared Data from Samsung Galaxy
Comparing with other data recovery tools, a professional Android data recovery software could be the best one. It is just the reliable and safe one, which is recognized as the No.1 Android data recovery software among multiple Android data recovery tools. It stands out with easy steps to get back disappeared data on Samsung Galaxy, including contacts, text messages, gallery, videos, call logs, calendars, documents, WhatsApp messages, etc,. It allow to scan and preview data before recovery. It has successfully helped over a large number of Android users to recover deleted data, and highly recommended by those users for Android data recovery.
Besides Samsung Galaxy S9 and other Samsung models(Samsung Galaxy S5/S6/S7/S8, Note 4/5/8/9), it compatible with all Android models and tablets, such as, ZTE, OPPO, Google Pixel, Huawei, LG, Lenovo, Motorola, Xiaomi, etc,.
LEARN MORE
Posted on Jan 03, 2019
    Top Expert:
  • 9,098 Answers
Half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Posted on Feb 04, 2016
SOURCE:
I have a problem with our Sony Bravia 32" inch..
It may be due to voltage variation.
TAKE IT TO A SONY DEALER AND ASK FOR REPAIR.
Aug 21, 2013 | Televison & Video
Our LN40A630 has three horizontal white lines across the screen on power up (center, center of upper half , and center of lower half). After about five minutes the lines go away. Tried Picture Test in...
This is a sign of your LCD panel beginning to die. Sometime soon those lines won't fade away and will become permanent parts of your TV screen.
Considering the fact that your TV is approx 3-4 years old, this is normally the expected lifespan of a TV. Once the TV becomes unwatchable, your best bet would be to begin shopping for a new one.
Mar 07, 2011 | Samsung LN40A630 40 in. LCD TV
Toshiba 27WL46 27 in.LCD- Lines top of screen getting worse.
If they are vertical lines, then the LCD panel is going bad, it will get worst with more lines appear as time goes on.
Jan 07, 2010 | Toshiba 27WL46 27 in. LCD Television
Only top half of screen has picture there is a white line through the centre and bottom half black
If this is a conventional TV with the original style Cathode Ray tube, this fault sounds like failure of the LINE OUTPUT TRANSFORMER.
It can be fixed, but may cost you around £70 ($120), possibly more if you have to call out an engineer.
Best NOT to use the TV as it is, because it will certainly damage the tube if you leave it running with that white line through the centre!!!
If you do use it, this line will become permanent and if you get the TV fixed later, there will always be a burnt section of the screen where the white line was - so I suggest you either pay to get it fixed right away, or consider buying a replacement.
Nov 17, 2009 | Televison & Video
Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Jun 01, 2009 | Televison & Video
RCA tv model F32649 white horizontal lines
the problem of your tv is in vertical section, to be sure change all the capacitor in vertical section.
Sep 27, 2008 | RCA F32649 32" TV
Bad picture
Try to consider the following tips:
Smearing out of one or several colors, best seen in txt-mode, my 27CE4599/30R smeared out in red and green, not in blue, fully exchanging the drivers (input and output complete, otherwise the RGB driver will blank the crt) moved the fault to the other color
Replace the 180K feedback resistors in the amplifiers with normal 1/4W metal film instead of 1/8W, they can become open circuited (in mine both green and red were faulty in this way). Change all 3 and not just the defective ones, replace also all the paralleled 75K resistors per color (fe by 47K+27K) to prevent bright color raster (they can also become open circuit)
Nov 29, 2007 | Toshiba 55H70 55" Rear Projection...
JVC A56P575
In the customer menu page thru it until you come to a page that has an item called convergence. move the cursor down to hightlight this and press enter. The next screen will have an Auto on the top line and a Manual of the second line. Hightlight the auto and press enter. The TV will attempt an automatic convergence alignment. BE WARNED>>>It will either correct it or make it worst. If it gets worst then the TV's convergence circuit has aged and is starting to fail. If it corrected it it's the same aging but not as bad, YET. If there is no change or it got worst then you will need to have the TV serviced preferbly by an authorized JVC service center because they have access to the service literature and buttetins.
Oct 08, 2007 | JVC AV-56P575 56" Rear Projection...
3 Inch block on right side top to bottom.
your best bet is to call hitachi do not mention unit being dropped raise all kind's of hell and hope for the best.
Jun 14, 2006 | Hitachi CMP4121HDU 42 in. Plasma...
Televison & Video Logo
429 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
