16 costly car noises - Bankrate.com
www.bankrate.com/finance/money.../16-costly-car-noises-1.asp...
BankrateYou should not ignore certain thumping, banging, clicking and squealing sounds. These sounds often rear their heads or intensify whenever the driver takes ... Hissing or sizzling under the hood: Heard when the engine is first shut off, .... my rear right wheel makes a loud bang when switching from park to drive/reverse.
Sounds coming from drivers side front wheel - AnandTech Forums
forums.anandtech.com > Social > The Garage
AnandTech
Dec 1, 2009 - 21 posts - 10 authors
Sounds coming from drivers side front wheel The Garage. ... slightly left, I get a slight metalish-squealing sound coming from the drivers side front wheel area. ... but before I start the wild and expensive goose chase of bringing it to mechanics I ..... Those twoloud clunks when turning hard right give it away.
Ford Explorer Questions - Thumping from front end - CarGurus
www.cargurus.com > Questions > Ford > Explorer
CarGurusDec 22, 2009 - Thumping from front end - I have a hard thumping noise coming from ... without problem then I'll take a turn or something and it will start. ... I just recentlystarted having a rubbing and thumping and squeaking noise in the right front sidewhen driving ... Thumping sound coming from under the truck 4 answers.
Car Noises: Consumer Reports - Consumer Reports Online
www.consumerreports.org/cro/...noises/.../index.htm
Consumer Reports
SOURCE: Thumping sound
If the sound is a thumping as you corner it is probably a torsion bar mount on the drivers side, fairly cheap and easy repair. Can't remenber weather it is the drivers or passenger side but one side you need to grind or cut down th bolt which attaches to the torsion bar. Have my 91 S10 blazer since 91 and have done several. Hope this helps.
SOURCE: loud screeching under hood passenger side
How about checking the fan belts, they may need adjusting or replacing.
SOURCE: driver side power door lock makes loud thump noise
the power lock actuator inside the door is worn out. this is a common sign where it will fall but not rise.
Like all noise problems posted here I always suggest you have a local shop listen to the noise. The reason is this, can't hear the noise over this keyboard.
SOURCE: 2002 toyota corolla thumping noise between 30 j 40 mph
If it only did it once then it was a road problem most likely and not the car.
