Here is the parts breakdown. Your model is discontinued.
The hand lever unscrews, the part that holds the handle looks like a push fit and then there is a screw collar holding the cartridge. Increase Zoom to 200%.
It looks like they disagree with me, and their way is easier!
F Cashman
· a year ago
I need to remove the faucet handle to fix a leak and I don't know how to remove the handle -please help
Moen Plus Support · 11 months ago
Hello F Cashman and thank you for your interest in Moen products. The handles for the Moen Waterhill Chrome Two-Handle High Arc Kitchen Faucet are removed by holding the lever stationary, while unscrewing the base of the handle hub counter-clockwise to remove the complete handle. If you have additional questions, please do not hesitate to contact us directly. https://solutions.moen.com/Article_Library/Kitchen_Handle_2H%3A_Threaded_Hub
Step 1 Turn off the water to your faucet. Step 2 Remove the handle to the faucet. Remove the small screw under the lever handle with an Allen wrench or Phillips head screwdriver, depending on what type of screw is present. Slide the handle back and off the faucet. Step 3 Remove the temperature control knob, which is the round, dial-shaped fitting over the faucet cartridge. Put the manufacturer-supplied adapter on the cartridge. Line up the lever stop pin with the arrow symbol on the cartridge. Step 4 Turn on the water and rotate the adapter to the left, or counter-clockwise, until the water temperature is at the level you want. Take note of the number to which the adapter points. Step 5 Shut the faucet off by turning the adapter to closed and line up the limit stop dial with the number you noted previously. Step 6 Assemble the faucet by replacing the temperature control knob and handle, then tighten the handle screw. Turn on the water and operate the faucet. If temperature is not set properly, repeat as necessary until you achieve the right setting.
MOEN CARTRIDGE REPLACEMENT
There are two different types of Moen cartridge for a single handle valve. The first and most common one is the plastic 1225 cartridge that is used for all Moen single handle valves that are not posi-temp shower valves. This cartridge also comes in brass which is number 1200, but it is more expensive and doesn't last any longer or work any better than the plastic cartridge. The posi temp cartridge is a number 1222. This is the replacement cartridge for shower valves that you turn rather than pull. As you turn the valve it goes from cold to warm to eventually hot. The tools needed for this procedure are pliers, Phillips screwdriver, a small flat screwdriver or awl, a 3/4 inch copper cleaning brush, silicone or heat proof grease, a knife to pull the cap on an acrylic handle, or a 7/64 inch Allen key to remove lever handle.
If it is an acrylic handle simply pry off the cap and unscrew the screw with a Phillips screwdriver. If it is a lever handle there is a set screw which is 7/64 of an inch. Use an Allen key to remove this set screw. If it is a lever handle when the handle is removed you must use a Phillips screwdriver to remove the handle adapter.
Before removing the cartridge make sure that the water is turned off and open the valve to bleed off the pressure. Leave the valve in the open position as it will facilitate the removal of the cartridge if the spindle is in the open position. It can be turned off at the main which is usually the easiest thing to do, or you can remove the faceplate and there may be integral stops behind the faceplate. Use the integral stops if your water main is hard to reach. On the brass spindle of the cartridge there is a notch on one side. Before you remove the cartridge take note of what position this notch is in because that is the position in which the cartridge will be placed. Do not forget this step as a posi temp cartridge will not function properly if installed with the notch in the wrong place. If you install the regular cartridge with the notch in the wrong place, hot and cold will be reversed. Simply remove the handle and spin the spindle 180°.
Pull off the chrome stop tube that encloses the cartridge. There is a horseshoe-shaped retainer clip that must be removed. Use the small screwdriver or all to pry up the top of the retainer clip. A plastic square head removal tool comes with the cartridge that you have purchased. Place this on the cartridge and spend back and forth to loosen the cartridge. Then take your pliers pull the brass spindle straight back towards you. If this proves too difficult and you are unable to pull it out you will have to buy a Moen cartridge pulling tool. Be sure to buy the right tool as they are not interchangeable. The posi temp tool is much fatter than the regular tool. The tool operates the same way a hub puller. Back off the knot on the tool as well as the screw. Place over the cartridge and advance the screw all the way. Now advance the nut.
After the cartridge is removed take the 3/4 inch copper cleaning brush and insert into the cartridge housing while spinning clockwise. When removing the brush also keep spinning it clockwise. After brushing, open the water main for about three seconds to flush the line out.
When installing the cartridge make sure that your notch is aligned properly and that the cartridge is pushed in all the way and that the two tabs on the cartridge are aligned vertically. Install the retainer clip. If it doesn't go in all the way either the cartridge has not been pushed in foreign off or the two tabs are not aligned properly. You can use the plastic tool to align the tabs properly and to help push in the cartridge all the way. Reassemble faceplate and handle and you are done.
It sounds like you have something jammed within the cartridge. You can either remove the cartridge and flush line and reinstall it or just buy a new cartridge and replace the old one. The cartridge you need is a number 1222 mowing positive cartridge. Here are instructions to change the cartridge.
faucet needs new gaskets and springs located below the handle. remove handle, loosen collar nut and remove, pull cartridge out straight up, remove gaskets and springs, take to local Home Depot and buy new and replace. install cartridge, install collar nut, install handle. All finished.
The single handled faucets have a valve cartridge which needs to be replaced when it leaks. Disassemble the handle to find the valve inside. Take the valve to the hardware store to be sure you get the right one and reassemble. To disassemble, pop the cap off the lever, unscrew the single screw, then use slip-joint pliers to loosen the retainer nut. lift the cartridge out with pliers taking note of the direction of the notch at the top of the stem. Be sure to reassemble with the notch facing in the same direction. You should replace and lubricate the O-rings when you change the valve cartridge. Since you have the numbers for that particular faucet, you might want to call around to find the cartridge first. Different models have different valves, so be sure yours is correct.
The water supply should have no bearing on the working motion of the faucet cartridge or handle. On both models of Moen faucet, the handle needs to be hooked under the cartridge's top cam bearing. It is a bit tricky sometimes. Here's the parts view for 7300 and 7310Moen Kitchen faucet. Parts view for 7100 Moen.
If you need further assistance please let us know.
pop cap off and remove screw,pull handle,now lift up on cartridge ,then position handle assembly on,make sure you hook around groove and set down.tighten up if it's a newer model,it will be a hex screw , but similar process
You need to hold handle lever and unscrew the bottom escuteon plate you may need a small strap wrench it will turn counter clockwise. On some older models there was a set screw on the handle which you would use an allen wrench
