NorStar T7316E Corded Phone Logo
A
Anonymous Posted on Feb 03, 2016
Reset Admin password NorStar T7316E Corded phone?
BT will not supply us with the admin password in order to change the time and extensions as we do not have a maintenance contract with them (ridiculous after purchasing the system!!)x4 line extensions Does anyone know how to reset the Admin password?? Any advice will be most welcome, thanking you in advance.
deton8 von Splosion
Level 3:
  • NorStar Master 3,342 Answers
  • Posted on Feb 04, 2016
deton8 von Splosion
NorStar Master
Level 3:
Answers
3342
Questions
6
Helped
928822
Points
54123
You NEED to get SYSTEM documents (Hard Copy or CD)
for NORTEL NORSTAR CICS before TAMPERING ...URL posted below...
Found on page 24:
Default Password Code is "admin" on your phone dial... Done by pressing 23646 on your phone dial...
Time feature is accessed by inputting **8463 = (**TIME)
Hope this helps...
(CAUTION: read & understand BEFORE programming)
http://phone.manualsonline.com/manuals/mfg/nortel_networks/compact_ics_61_system_coordinator.html?p=24
  • Anonymous Feb 04, 2016
    Hi
    Thank you very much for your help. Unfortunately the default passwords are not relevant as BT hold a specific password for our company but will not advise unless we take out maintenance. I am trying my upmost to override their code but unsuccessful in doing so thus far.
    I appreciate your help and many thanks once again.
I'm trying to change the display names for each extension but when i try the **266344 a user id option pops up....not for a password. What do i do?
Try pressing the FEATURE button then, **266344. On some Norstar phone systems there is also an Admin level of programming that is useful if you only need to change the names or the time. To access Admin programming, press Feature**23646(spells admin on the dial pad). Then 23646 for password.
5helpful
We have a Nortel Networks system T7316. One phone has the mailbox locked out and says contact admin. I have tried the 120000 code and it is invalid. What else can I try?
Feature 983 log in is 120000 (if 2 digit extension, 1020000 if 3 digit, 10020000 if 4 digit extensions)
Select Mbox, enter that locked extensions mail box number, You will see password RESET. Select RESET. Release out. This will reset that mail box password to 0000. Use feature 981 on that phone and enter the new default password of 0000. you will then be prompted to change the password.
So in other words, try 1020000, 10020000, 120000
1helpful
Dont know password - Mail Box Locked Norstar T7316? Tried previous descriptions - still says Mailbox Locked contact admin
Try below
You will need to dial into the system admin of the voice mail
Feature 983
the password is dependent on how many digits your extensions use. 1020000 for 3 digit and 10020000 for 4 digit, 120000 for 2 digit.
go through the screens
Mailboxes, modify, scroll to password and press change.
Will reset to 0000.
2helpful
My mailbox was locked, it said contact admin. i followed earlier instructions to F983 and then enter 120000 for two digit extensions. my phone says that password is invalid. how is this possible? i...
Sounds like the password was changed somehow.
to reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000.
9helpful
We have Nortel T7316. I have been locked out of the voicemail admin. I have tried all passwords I can think of but cannot get in. Please help
How do I reset a password on a Norstar Voice Mail mailbox?
Press Feature 983.
Enter the System Coordinator's Mailbox number (default is 12, 102, 1002, depending on length of extension numbers) followed by Password (default 0000).
Press MBOX.
Press CHNG.
Enter the mailbox number that is giving you troubles.
Press RESET. The password has been reset to default (0000).
Good Luck.
2helpful
2answers
Nortel T7316e need to change extention # on phone
You can go to any T7316e phone and do this , press feature 983 when you see log on the screen enter 102 0000 to log on with or 12 0000 this is the default admin password for the voice mail system . it depends if you have a 3digit extension of 2 digit . when you get in you will see three options on the screen above the three buttons , from left to right it will be mbox aa and other press the mbox button then it will give you three more options again from left to right they will be add delete and change press change , it will ask for the extension number , enter the number of your extension . the thing it will ask you is if you want to reset the password , press yes and the press the the red rels button your password is now reset to 0000 . good luck .
3helpful
3answers
After I have entered user id and password and the
Are you using the installer password or the admin password?
1helpful
Change extension name
System Admin access is available from any 7310 or higher model phone. You need a password and overlay..or a picture of what the buttons do in programming.
Carl
2helpful
Employee's mailbox locked and No one knows Admin password
Jessie711 - You Rock! Your post on the 21st fixed my problem :)
16helpful
NorStar T7316E Corded Phone Problem - mailbox locked
You will need to dial into the system admin of the voicemail
Feature 983
the password is dependant on how many digits your extensions use. 1020000 for 3 digit and 10020000 for 4 digit, 120000 for 2 digit.
Will reset to 0000.
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
