No video or audio from HDMI inputs, (DirecTV and Xbox), rca aux input or Component input. Over-the-air HDTV from the Antenna is perfect audio & video
No video or audio from HDMI inputs, (DirecTV and Xbox), rca aux input or Component input. Occasionally, I will get audio static or a brief flash of video snow but most times no audio/no video. Here's the odd part: Over the air HDTV from the antenna gives me perfect video and audio! Where does the problem likely lie if HDMI/Component sources won't work but Antenna HDTV is fine? Replaced a bulged capacitor on the power supply board, but this didn't fix my problem. Any guidance would be appreciated
YouTube video wasn't helpful. It's not just a failed HDMI port (actually two ports). It's also the aux input and the component video inputs. But, as stated before, the Over the air hdtv works perfect. An expert should be able to discern at least approx. where the problem lies from the specific symptoms described. It's NOT just a failed HDMI port.YouTube video wasn't helpful. It's not just a failed HDMI port (actually two ports). It's also the aux input and the component video inputs. But, as stated before, the Over the air hdtv works perfect. An expert should be able to discern at least approx. where the problem lies from the specific symptoms described. It's NOT just a failed HDMI port.
You can't post conmments that contain an email address.
? 2:34
https://www.youtube.com/watch?v=ZtaUPX1tHP0
May 26, 2015 - Uploaded by ShopJimmy.com
Basic troubleshooting and replacement tips for HDMI inputs that are not ... video or audio from your HDMI port, you can take the source video ...
CNETJun 14, 2014 - Sunday my husband hooked up an RCA ANT571 antenna with great results. ... The Roku first showed no signal on the TV. I tried hooking the Roku up to other HDMI ports, i changed the hdmi cables, .... Sound comes through, but not picture. ..... Video; All Video · Apple Byte · Carfection · CNET Top 5 · CNET ...
Oct 11, 2012 - The video is excellent, but there is no sound coming out of my TVspeakers. ..... I also tried inputs besides the "HDMI 1" input and the other RCA ...
The highest quality lowest priced TV parts DLP lamps TV stands refurbished TVs more 400 000 television parts 300 brands Vizio LG Samsung Sony Philips more Toll free 877 881 6492
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Looking
at the specs for your TV, it does not appear to have the jack for
earphones.
You
will have to connect an audio receiver to
your TV and use the reciever's jack.
Connectivity
HDMI ports qty4
PC interfaceVGA (HD-15)
Input/Output connections3 x HDMI (19 pin HDMI Type A) - Rear, 1 x HDMI (19 pin HDMI Type A) - Side, 2 x Component video input (RCA phono x 3) - Rear, 1 x Composite video/audio input (RCA phono x 3) - Side, 2 x USB (4 pin USB Type A) - Side, 1 x Ethernet (RJ-45) - Rear, 2 x Audio line-in (RCA phono x 2) - Rear, 1 x VGA input (15 pin HD D-Sub (HD-15)) - Rear
How do I connect direct tv to denon and then get sound If the RCA TV has HDMI input connect as follows: 1.Connect an HDMI cable from the Directv box to an HDMI input on the Denon. 2.Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV 3.Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV. 4.On front of denon press the input mode button to select auto If the RCA TV has Component input (Green,Red,Blue) connect as follows: 5.Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR). 6.Connect a Component Video cable from the Denon to the RCA TV Component Video input. 7.Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8.On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows: 9.Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR). 10.Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11.Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV. On front of denon press the input mode button to select auto
Are your DVD and cable actually going to the Onkyo first and then to the TV? I am assuming it is, if you listen to the Onkyo when watching a DVD or cable.
The Onkyo receiver you have has 2 hdmi inputs and 1 hdmi output.
Does your Xbox360 have an hdmi output and that is what you want to connect to the Onkyo? Some do and some don't.
If your Xbox has a hdmi output and you are already using the 2 hdmi inputs on the Onkyo, you can not connect the Xbox using the hdmi, you have no more hdmi to connect to, so you must go thru one of the other inputs of the Onkyo.
The hdmi has the video and audio together, the other video options do not. you would need to run seperate audio cables as well. Your Xbox should have a composite video (yellow RCA jack) output or a component video (1 red, 1 blue, 1 green RCA jack) output.
When you connect the Xbox thru, lets say the composite video of the Onkyo , you will also need to connect the audio from the Xbox to the Onkyo on the same input. It should be right next to the yellow RCA jack or right under it. They are 2 RCA jacks, one red and one white.
You will then need to connect the composite output of the Onkyo to the composite input of the TV.
When connecting like this, you will also need to select the composite input on your TV with your remote for your TV. Your TV should have an input button that lets you go thru all the different inputs to it.
you can also use the component video from the Xbox if it has that. But you must also run the audio to the Onkyo as well to the corresponding audio inputs of the component video input on the Onkyo.
This may sound a little confusing, but remember that the hdmi has the audio and video in one cable, the other video options do not, so you must run additional cables for the audio to the Onkyo from the Xbox.
Also remember whichever video you use from the Xbox to the Onkyo, you must also run that same video from the Onkyo to the TV and then switch the TV over to that input when you want to watch the Xbox on the TV
The Scientific Atlanta box was a cable box and recieved CATV signals. The Direct TV box is satellite only. You might check if it has a built in ATSC tuner for off air digital signals. Direct TV in most locations offers the major networks in HD format.
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
