Cell Phones Logo
Doris Gorman Posted on Feb 02, 2016
How can I turn it back on? - Samsung Cell Phones
MARIE ANN CRAWFORD
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 22, 2016
MARIE ANN CRAWFORD
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
72
Points
I AM TRYING TO GET INFORMATION ON HOW TO GET MY VERCASION ON MY PHONE MY NUMBER IS 573462 9725 IF SOME ONE COULD PLEASE HELP ME THANKS
  • Eddie Tam
    Eddie Tam Feb 22, 2016
    what's a vercasion? please delete your number.. people who help answer questions are not employees of your cellular company. call them for help.
2000 jag s type gas pedal does not work
TURN THE KEY TO RUN & OFF 3TIMES BACK TO RUN
PUSH THE PEDAL TOO THE FLOOR & QUIKLY LET OFF
TURN THE KEY TO RUN PRES THE PEDAL TO THE FLOOR & QUIKLY LET OFF 3 TIMES TO THE FLOOR BACK OFF TO THE FLOOR BACK OFF TURN THE KEY TO OFF TURN KEY BACK TO RUN SLOWLY PRESS THE PEDAL TO THE FLOOR & HOLD IT FOR 10-12 SEC
LET OFF QUIKLY KEY BACK TO OFF TURN BACK TO RUN & SLOWLY TO THE FLOOR HOLD IT 10-12 SEC LET OFF QUIKLY TURN KEY TO OFF THEN START IT SHOULD FIX YOUR PROBLEM
How do you backwash a pentair Above ground DE pool pump
turn off system turn multiport to back wash then turn system back on until water comes out clean then turn off turn dial to rinse turn on for 30 seconds then turn off then turn dial to filter then turn back on you should be ok make sure water isnt coming out the backwash hose if so kink it or plug it you should be ok
Oct 11, 2014 • Pool & Spa
Vizio will not power on, vizio emblem is off.
Did you check the power cord of intermittent connection.
1helpful
My wife entered the wrong pin number by accident on the nuvi 750. She tried turning the unit off and then back on to reset back to "enter pin" code mode however she gets the response "you must return to...
If you turn the unit off, wait about ten seconds and turn it back on, yes, it should go back to the "Enter PIN" screen. If, however, you turn it off then immediately turn it back on it will continue to tell you to return to the security location.
What is the tiny black button on the back of my black berry storm for? Its behind the back cover.
New Power / Lock button usage
Using the Power or Lock button on the top of the BlackBerry smartphone, you can perform the following tasks depending on the state of the BlackBerry smartphone:
State of the BlackBerry smartphone: Unlocked and the back light is turned on
Action: Press and release button.
Result: Locks the BlackBerry smartphone and turns off the back light.
Action: Press and hold button.
Result: Turns off the BlackBerry smartphone.
State of the BlackBerry smartphone: Unlocked and the back light is turned off
Result: Turns on the back light.
Result: Turns on the back light and displays the power off prompt.
State of the BlackBerry smartphone: Locked and the back light is turned off
Result: Turns on the back light and displays the unlock prompt.
Result: Turns on the back light and presents the power off prompt.
State of the BlackBerry smartphone: Locked and back light is turned on
Result: Presents the unlock prompt.
Action: Press and hold.
Result: Presents the power off prompt.
1helpful
Tv turn off and wont turn back on
Check the power supply board.
Please rate this a fixya
RAZR won't turn back on, it just freezes
Try opening up the back then take out the battery make sure there isn't any dust or anything foreign inside near the battery connections. Put the battery back in, close up the back. Turn phone back on.
1helpful
Jeep grand cherokee revs for to high before changing gear
Message:
My 2002 Dakota has been somewhat confused about shifting as well. It showed a code P1762. I dropped the pan to install a new fluid filter and fluid-(use only ATF+3 or ATF+4). Since the pan was off I decided to adjust the bands. The front band controls the 2nd gear cluster. The rear band controls the 3rd gear cluster and reverse. For a 2-3 shift, the transmission shifts back to 1st gear with the front band while the rear band engages 3rd gear. If the front band does not release the 2nd gear clutches before the third gear clutches engage, the transmission binds, which shortens the life of the transmission clutches. If the front band releases too early in the shift, the engine will overspeed (sounds and feels like a slip) during the 2-3 shift.
The front band adjusting screw is on the driver's side above the shift linkage. The rear band is inside the fluid pan near the filter.
1. Loosen band adjusting screw locknut. Then back locknut off 3-5 turns. Be sure adjusting screw turns freely in case. Apply lubricant to screw
threads if necessary. The front band adjuster is on the outside of the transmission and the locknut requires a 3/4" wrench.
2. Using Inch Pound Torque Wrench C-3380-A, a 3-in. extension and appropriate Torx� socket (T-40), tighten adjusting screw to 72 in-lb. CAUTION: If Adapter C-3705 (from SPX Miller) is needed to reach the adjusting screw, tighten the screw to only 47-50 in. lbs. torque.
3. Back off adjusting screw the number of turns listed below for your transmission.
4. Hold adjusting screw in place and tighten lock-nut to:
41 N�m (30 ft. lbs.) for the front band
34 N�m (25 ft. lbs.) for the rear band
The adjustment screw inside the case is a square head bolt. You will need a 1/4 square head socket to fit your torque wrench.
Band adjustments for each model year:
1994
* Front Band - tighten to 72 in-lb, back off 2-1/2 turns (all transmissions)
* Rear Band
o 32/42RH - Tighten to 72 in-LB, back off 4 turns
o 36/37/46/47RH - Tighten to 72 in-lb, back off 2 turns
1995-1996
* Front Band
o 42RH - tighten to 72 in-lb, back off 2-1/4 turns
o 46RH - tighten to 72 in-lb, back off 2-7/8 turns
o 47RH - tighten to 72 in-lb, back off 1-7/8 turns
* Rear Band
o 42RE/RH - tighten to 72 in-lb, back off 4 turns
o 46RE/RH - tighten to 72 in-lb, back off 2 turns
o 47RE/RH - tighten to 72 in-lb, back off 3 turns
1997-1998
* Front Band
o 42RE - tighten to 72 in-lb, back off 3-5/8 turns
o 46RE - tighten to 72 in-lb, back off 2-7/8 turns
o 47RE - tighten to 72 in-lb, back off 1-7/8 turns
* Rear Band
o 42RE - tighten to 72 in-lb, back off 4 turns
o 46RE - tighten to 72 in-lb, back off 2 turns
o 47RE - tighten to 72 in-lb, back off 3 turns
1999
* Front Band
o 42RE - tighten to 72 in-lb, back off 3 turns. (TSB 21-16-98)
o 47RE - tighten band adj. screw to 72 inch pounds, back off 1 7/8 turns
* Rear Band
o 47RE - tighten band adj. screw to 72 inch pounds, back off 3 turns
+ The 47RH rear band requires a 1/4" hex driver, the front band requires a
T-30 Torx driver, the filter is held in place by two screws which require a T-20 Torx drive
2000-2002
* Front Band
o 42RE - Tighten band adj. screw to 72 in-lb, back off 3 turns
o 44RE - Tighten band adj. screw to 72 in-lb, back off 1 7/8 turns
o 46RE - Tighten band adj. screw to 72 in-lb, back off 2 7/8 turns
o 47RE - Tighten band adj. screw to 72 in-lb, back off 1 7/8 turns
From Bill Konolday's 47RE notes: I usually go a little looser than factory
specs on this front band - backing off the adjustment screw 2 or 2 1/4 turns.
Depending on the circumstances I have backed off the band up to 2 1/2 turns.
* Rear Band
o 42RE - tighten band adj. screw to 72 inch pounds, back off 4 turns
o 44RE - tighten band adj. screw to 72 inch pounds, back off 4 turns
o 46RE - tighten band adj. screw to 72 inch pounds, back off 2 turns
2003
* Front Band
o 48RE - tighten band adj. screw to 72 inch pounds, back off 1-3/4 turns
* Rear Band
o 48RE - tighten band adj. screw to 72 inch pounds, back off 3 turns
2005
* Front Band
back off front band adjusting screw 1-3/4 turns for diesel vehicles,
or 1-1/2 turns, for V-10 vehicles.
* Rear Band
94+ Automatic Transmission Bolt and Nut Torque Specs
* Front band adjustment locknut - 30 ft-lb
* Rear band adjustment locknut - 25 ft-lb
* Transmission pan bolts - 13 ft-lb
I just replaced the solenoid with the recommended transducer and all is fine now. The transducer cost me about $50 at a nearby dealership.
Hope this helps. -zman. [email protected]
Ultra viewsat box vs2000 froze
change the file make sure you check the mane of thefile
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
