I have a Juki TL-2010Q sewing machine. I have had recurring problems with skipped stitches. Had the timing fixed this summer, but am again faced with skipped stitches. Can anyone describe how to fix the timing. I'd like to avoid another $90 charge! Thanks!
Have you replaced your needle first. Sometimes simply a new needle will do the trick. That Juki being a straight stitch only machine make it simple. When the needle reaches its lowest point and then starts back up about an eight of an inch. The point of the hook should be slightly above the eye of the needle and be directly behind the needle shaft.
