Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls Logo
C
Cathy Petrou Posted on Feb 02, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The light comes on when I press start but no menu pops up
Aced
Level 2:
Sergeant:
Habit-Forming:
  • Expert 54 Answers
  • Posted on Feb 02, 2016
Aced
Expert
Level 2:
Sergeant:
Habit-Forming:
Answers
54
Questions
Helped
39290
Points
668
System board problem, have repairmen verify and change
My hisense tv keeps popping up the menu constantly
Probably a stuck button, either the menu button on the set itself is stuck or a menu button on a remote is active. Press the menu button on the set itself and see if that "un-sticks" the button, if it was indeed stuck. If the menu keeps popping up, take the remotes from the room and go back in without the remotes and see if the menu is popping up. Try the menu button again on the TV itself to see if that changes things. If the problem was a remote, perhaps it was laying wrong and depressing a button. Or, a button on it may have indeed been stuck. Bring the remotes back in and see if the menu starts popping up.
Cursor has frozen what can i do
Couple of things you can try
Try 1 :
1. Press the windows key on your laptop and see weather the start menu pops up 2. If it pops up then the problem is with your laptop touch pad 3. Try ALT+CTRL+DELETE 4. Use the TAB to get to the Turn Off button and click that then turn on again
Try 2: 1. If the windows start menu did not pop up 2. Then your laptop is stuck 3. Press and hold the physical on/off button of your laptop then your laptop will turn off
How do i use the micophone
To start voice recording, follow these steps:
1. Press the Menu button to return to Main Menu.
2. Select Voice
3. Press Play/Pause to start recording.
4. To pause recording, press Play/Pause again
5. To stop recording, press Select. A pop-up window will appear on the screen. Select Yes to
save recording. The recording will be saved in the RECORD/VOICE folder.
6. Press 'button to return to the Voice Menu.
39helpful
2answers
What is opc that pops up about every 10 Min
OPC is optical picture control. The television is adjusting itself to the lighting in the room. Even if someone walks in front of the television's sensor it will start to adjust and you will see opc on the screen and green leaves.
You can leave the feature on without the opc and green leaves appearing on the screen. Press the menu button. Scroll down to OPC. Press enter. Scroll to on. Press enter. Press menu to exit.
3helpful
2answers
How do I turn off the low tire pressure light?
Owners manual; or may have to go to dealership.... The info starts on page 5-66 under "Tire pressure Monitor System" hope it helps.
If you cut off the radio press and hod the the tune button until tire pressure pop up then press the tune button again and it will reset.
Our tv works excellent except it started to have a pop up that says "Toshiba Color TV, etc." and another pop up regarding the settings. Can't get it to stop. Can you help?
Viewing the demonstration (DEMO) mode
The DEMO mode automatically demonstrates several features of
your TV.
To start the DEMO mode:
1. Press MENU.
2. Press < or >to highlight the SET UP menu.
3. Press up or down to highlight DEMO.
4. Press < or > to highlight START.
To stop the DEMO mode:
Press RECALL, EXIT, or POWER. This should do it for you. Thanks for using fixya.
5helpful
My 2007 paficia perferom service light keeps coming on and i already had a oil change it only has 60,000 miles and I was told it is not time for a tune up. why the light will not stop popping up?
Change the service interval on the menu button on the dash. Scoll through the menu till you get to the service miles hit the step button until you reach the next desired service miles. Then press the menu button once it will ask u reset service hit the step button twice this will reset the perform service light. Hope this helps please rate if it does.
8helpful
3answers
OSD LOCKOUT
1. Replaced the Micro switchs.
2. press the menu switch 15 to 20 secunds.
Sansui DVD Recorder Model HDR 120GB
put Dvd back into unit- press DVD on remote- DVD light will light up on the unit- press "set up "button on the remote- a screen will come on - use remote arrows to go down to system set up- press enter- another add on menu apprears -use arrows on remote to choose "disc set up" press enter- another menu appears- go to "finalize" press enter - a pop up menu appear- choose "yes" and wait until disc finalizes- finished and usable in any DVD player. This is on page 27 and 28 in the manual. Have fun- DD
Top Electrolux Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
