Mercedes S-class S500 S55 S430 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2000 2001 2002 Logo
T
THERESA SATTERFIELD Posted on Feb 01, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 2001 MB S430 Passengers Windows & seat heater & seat adjustments stopped working
ALL THE SWITCHES ON MY PASSENGERS DOORS ARE NO LONGER WORKING. THE SEAT HEATER, WINDOWS AND SEAT ADJUSTMENT NO LONGER WORK AT ALL.
David Payne
Level 3:
Top Expert:
  • Mercedes-Benz Master 14,162 Answers
  • Posted on Feb 18, 2016
David Payne
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2998486
Points
455836
2000 mercedes s430 both front window don't work and passenger seat adjustments don't work. How to solve this issue?
How to solve this issue? Do you know how to test electrical systems on a Mercedes, have a repair manual with wiring diagrams ,shows fuse locations for those systems . Using a DVOM - digital volt ohmmeter test for battery voltage at the fuse, at the connectors to door switches an seat switch. Or just take it to a qualified repair shop.
2answers
Passenger windows wont work and power seats not working?2007 gmc yukon denali xl
Check in the under hood fuse block or power distribution center for fuse #72 and #75 these are 60 amp fuses. If the problem isn't there you have Two separate problems, check at the switches for battery voltage and ground. The most common problem is switches.
ALL THE SWITCHES ON MY PASSENGER DOORS STOPPED WORKING. FOR WINDOWS & SEAT HEATER & SEAT ADJUSTMENTS
Hi there my name is Brandon I am a mechanical n electronic engineering technician it sounds like you have a fuse blow for that circuit
1helpful
Door motors (controls for the seat adjustment & window operator) won't work unless either the passenger or the driver door is open. How to fix?
take to dealer system is hard to diag even with all info at hand because each door and window has sensors that send singals to a body control that processes and then lets work.
2helpful
3answers
I have a 2002 Oldsmobile Bravada...Yesterday all of a sudden my passenger's side window stop working(up and down)...the power lock and the heated seat all stop working on my passenger's side...?
If you have an Owners manual, try looking for a fuse panel diagram. Your could have a bad connection inside the doorpanel which shorted the fuse. The seat drive motor must be wired to a separate circuit coming from the floorboard and its okay.
The circuits are wired independently to protect the lighter wires from the heavy drain of the seat motor. If you had the heated seat function working on the seat at the same time as adjusting the seat motor it would be too much for a single circuit, so they gave you two circuits.
If you are going to work on the door panel, disconnct the NEG battery cable so you won't short out something taking it apart.
Another Repair place you might try is a Glass Replacement shop. They install the inner workings of window tracks daily and remove the door panels to do it. They would be able to find your wires, test your window motor, and get you on your way quickly.
Unlike a Dealership, they have a high turnover of glass installations daily. Some even come to your house to repair your problem. Your car would be repaired more quickly with these services.
I have a 2008 Chevrolet Silverado 1500, extended cab, automatic truck.......PROBLEM, the drivers side has a power seat, it will not move in any direction and the passenger side front and rear power windows...
How to diagnose this problem ? Viewing wiring diagrams to see what all is invovled in these electrical circuit's , check power supply's an ground connection's using a DMM - digital multimeter !
What type power seat's ? does it have memory ,heated an cooled etc ?
Power Seats System Description and Operation
There are 2 options of power seat systems available in full size trucks. The first is 6 way driver and passenger power seats without memory. The second is an 8-way driver seat plus 4-way lumbar with memory, heat and optional cool function. While the passenger has 8-way power seats with heat and optional cool function. For the driver memory seat operation, refer to Memory Seats Description and Operation. Power seats without memory are completely controlled through the power seat switch. Battery voltage is supplied to the power seat switch through the power seat circuit breaker. While the seat adjuster switches are in an inactive state the switch contacts are closed to the power seat switch ground circuit. When a power seat switch is pressed to an active state the switch contact is closed to the battery voltage supply circuit. Each seat adjuster motor is controlled by the power seat switch through 2 motor control circuits. The seat adjuster motors are bidirectional and the direction of adjuster motor rotation is determined by which of the adjuster motor control circuits is switched to battery voltage while the other remains grounded.
If it has memory seat's there is a control module !
Battery voltage is supplied to the driver seat module through a 25 A circuit breaker. The driver seat module supplies the seat adjuster switch assembly with a battery positive reference voltage. While the seat adjuster switches are in an inactive state the switch contacts are closed to the adjuster switch common circuit.
Both right side windows have a seperate power supply from the left side window's ,has RT DOORS circuit breaker CB1 - 25amp. location left instrument panel fuse block . Circuit breaker's very rarely fail .Do the door lock's work on that side of the vehicle ? The windows won't work with their own switche's ?
The DDS controls the passenger window through a GMLAN message to the PDS. When a power window switch is activated in the up or down positions the PDS supplies power and ground to the window motor control circuits to drive the window motor in the required direction. Prior to activating a power window motor the PDS will supply the control circuit with a low current bias voltage in order to determine that a short to ground condition does not exist, and during window motor operation the PDS continues to monitor the motor current to verify proper window motor operation. (Scan tool support is available for this system)
Check PDM fuse 4 15 amp ,this supply's B+ voltage to the DOORLOCK/WINDOW switch passenger side . Check for broken wires inside the flex boot from the body to the passenger door .
I NEEDED THE 2001DODEGE CARAVAN SPECIFICATION
2001 Dodge Caravan Performance Features -3,301 cc 3.3 liters 6 V engine with 93 mm bore, 81 mm stroke, 9.3 compression ratio, overhead valve and two valves per cylinder
-Unleaded fuel
-Fuel economy EPA highway (l/100km): 9.8
-Multi-point injection fuel system
-Main 76 liter unleaded fuel tank
-Power: SAE and 134 kW , 180 HP @ 5,000 rpm; 210 ft lb , 285 Nm @ 4,000 rpm
2001 Dodge Caravan Handling & Driving Features -ABS
-Two disc brakes including two ventilated discs
-Spacesaver steel rim under body spare wheel
-Strut front suspension with stabilizer bar independent with coil springs , beam rear suspension with stabilizer bar rigid with leaf springs
2001 Dodge Caravan Exterior Features -Body side molding
-Front and rear body color bumpers
-Driver and passenger power heated black door mirrors
-External dimensions: overall length (mm): 4,803, overall width (mm): 1,996, overall height (mm): 1,750, wheelbase (mm): 2,878, front track (mm): 1,600, rear track (mm): 1,626 and curb to curb turning circle (mm): 11,460
-Complex surface lens halogen bulb headlights
-Double sliding minivan side door
-Remote control operation opening rear ¼ windows
-Metallic paint , gloss paint , pearl paint
-Fixed rear window
-Tinted glass on cabin, rear and side
-Weights: curb weight (kg) 1,842, gross trailer weight braked (kg) 907 and max legal load (kg) 772
-Windshield wipers with variable intermittent wipe
2001 Dodge Caravan Interior Features -Air conditioning with rear outlet
-Fixed mast antenna
-Manufacturer's own audio system
-Automatic drive indicator on dashboard
-Below seat storage under passenger seat
-Cargo capacity: all seats in place (liters): 433, all seats removed (liters): 4,154 and third row seats removed (liters): 1,291
-Clock
-Dashboard full console with open storage box
-Delayed/fade courtesy lights
-Cruise control
-Front seats, rear seats and 3rd row seats cup holders
-Door ajar warning
-Door pockets/bins for driver seat and passenger seat
-Floor covering: carpet in load area
-Driver and passenger front airbag
-Bucket seat
-3-point reel height adjustable front seat belts on driver seat and passenger seat
-Front seat center armrest
-Glove compartment
-Height adjustable two head restraints on front seats, rear seats and 3rd row seats
-Internal dimensions: front headroom (mm): 1,011, rear headroom (mm): 998, front hip room (mm): 1,440, rear hip room (mm): 1,722, front leg room (mm): 1,031, rear leg room (mm): 930, front shoulder room (mm): 1,588 and rear shoulder room (mm): 1,643
-Low fuel level warning
-Low washer fluid level warning
-Internal button power locks
-Power steering
-Front power windows with one one-touch
-Front reading lights
-3-point reel height adjustable rear seat belts on driver side and passenger side
-Bench one-piece two rear seats
-Rear view mirror
-Upgraded cloth/velour seat upholstery
-Seating: seven seats
-Six speakers
-Plastic steering wheel
-Tachometer
-3-point reel third row seat belts on driver side , 3-point reel third row seat belts on passenger side , lap static third row seat belts on center side
-Front facing bench removable one-piece third row seats with capacity three
-Driver and passenger vanity mirror
-Ventilation system with recirculation setting
Thanks.
The windows don't work right
If the passenger front window switch operates up & down correctly the left drivers side switch is bad and needs a replacement switch
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
