Check in the under hood fuse block or power distribution center for fuse #72 and #75 these are 60 amp fuses. If the problem isn't there you have Two separate problems, check at the switches for battery voltage and ground. The most common problem is switches.
Do you know what a wiring diagram is ? How to use a DVOM - digital volt ohmmeter to test electrical circuits ? View wiring diagrams to see what all is involved in making the windows work . 05 Lexus probably has a electronic control module used to control windows . Does the passenger window only work from it's door switch ? Does the driver master switch open / close that window ?
Not a fuse issue , more then likely a burnt heating element in the seat , happens all the time .
Heated Seat Components
The heated seat system consists of the following components:
• Driver and passenger heated seat switches
• Driver and passenger seat back heater elements
• Driver and passenger seat cushion heater elements
• Driver and passenger seat back temperature sensors
• Driver seat module
• Driver door module
• Passenger door module
The control module have a Battery voltage supply , the module supply's voltage to the seat heating elements .
The heated seat switches are momentary contact switches and are inputs to the driver and passenger door modules. Battery voltage is supplied to the switch assembly from the door module, and when a heated seat switch is pressed and released a brief switch signal voltage is supplied to the door module. Whenever the door module receives an active heated seat switch input, the next heated seat operating mode is determined by whatever the current mode may be. The seat heater elements are controlled by the driver seat module using inputs from the door modules through Class 2 serial data circuit messages. The driver seat module controls the voltage supply and the ground circuits to the seat heater elements. When a heated seat function is commanded active, the seat module will switch battery voltage to the heater element supply circuits, and ground is provided through low side drive control circuits. During heated seat operation both the seat back and cushion heater elements are supplied battery voltage. The seat module grounds the appropriate control circuits for back only or back and cushion heating modes, and opens or closes the active control circuits as necessary in order to maintain the desired seat temperature. The seat module relies on inputs from thermistors located in the driver and passenger seat backs to control heated seat temperatures. The thermistors are 2 wire sensors supplied with a 5-volt referenced signal circuit and a low reference circuit from the seat module. Resistance through the thermistors varies with temperature causing the heated seat sensor signal circuit voltage levels to decrease as the seat back temperatures rise. The seat modules allow heated seat operation only while the engine is running which is determined by a Class 2 serial data circuit message from the powertrain control module.
Your best bet , take it to a qualified repair shop.
Do you know what a electronic module is ?
DTC B2425 or B2430
Circuit Description
The driver and passenger seat heaters are controlled by the driver seat module. Power is supplied to the driver seat cushion and back heater elements through individual voltage supply circuits. Power is supplied to the passenger seat cushion and back heater elements through a common voltage supply circuit. All of the driver and passenger seat heater elements are grounded by the driver seat module through individual low side drive control circuits. The heater element control circuits are pulse width modulated to ground by the driver seat module in order to control the seat temperatures by regulating the current flow through the heater elements.
DTC Descriptors
This diagnostic procedure supports the following DTCs:
• DTC B2425 Driver Seat Heater Circuit
• DTC B2430 Passenger Seat Heater Circuit
Do you know what a DTC - diagnostic trouble code is.
Electronic's ! drivers Power seat module , driver door module . Do you know anything about automotive electronic's ?
The heated seat module (MSM) controls heated seat operation for both the driver and passenger seats. There are 2 modes of operation available for heated seats; both the seat cushion and seat back heat, or seat back only heat. When a heated seat temperature signal request is received, the MSM will activate both the seat cushion and seat back heating elements. When the heated seat BACK ONLY mode button is pressed once the MSM will deactivate the seat cushion heating element and leave the seat back heating element ON.
The adjustable pedal system is controlled by the memory seat module (MSM).
your best bet , have a qualified repair shop check it out ! Could have DTC'S - diagnostic trouble codes in door module , BCM etc...
take to dealer system is hard to diag even with all info at hand because each door and window has sensors that send singals to a body control that processes and then lets work.
If you have an Owners manual, try looking for a fuse panel diagram. Your could have a bad connection inside the doorpanel which shorted the fuse. The seat drive motor must be wired to a separate circuit coming from the floorboard and its okay.
The circuits are wired independently to protect the lighter wires from the heavy drain of the seat motor. If you had the heated seat function working on the seat at the same time as adjusting the seat motor it would be too much for a single circuit, so they gave you two circuits.
If you are going to work on the door panel, disconnct the NEG battery cable so you won't short out something taking it apart.
Another Repair place you might try is a Glass Replacement shop. They install the inner workings of window tracks daily and remove the door panels to do it. They would be able to find your wires, test your window motor, and get you on your way quickly.
Unlike a Dealership, they have a high turnover of glass installations daily. Some even come to your house to repair your problem. Your car would be repaired more quickly with these services.
How to diagnose this problem ? Viewing wiring diagrams to see what all is invovled in these electrical circuit's , check power supply's an ground connection's using a DMM - digital multimeter !
What type power seat's ? does it have memory ,heated an cooled etc ?
Power Seats System Description and Operation
There are 2 options of power seat systems available in full size trucks. The first is 6 way driver and passenger power seats without memory. The second is an 8-way driver seat plus 4-way lumbar with memory, heat and optional cool function. While the passenger has 8-way power seats with heat and optional cool function. For the driver memory seat operation, refer to Memory Seats Description and Operation. Power seats without memory are completely controlled through the power seat switch. Battery voltage is supplied to the power seat switch through the power seat circuit breaker. While the seat adjuster switches are in an inactive state the switch contacts are closed to the power seat switch ground circuit. When a power seat switch is pressed to an active state the switch contact is closed to the battery voltage supply circuit. Each seat adjuster motor is controlled by the power seat switch through 2 motor control circuits. The seat adjuster motors are bidirectional and the direction of adjuster motor rotation is determined by which of the adjuster motor control circuits is switched to battery voltage while the other remains grounded.
If it has memory seat's there is a control module !
Battery voltage is supplied to the driver seat module through a 25 A circuit breaker. The driver seat module supplies the seat adjuster switch assembly with a battery positive reference voltage. While the seat adjuster switches are in an inactive state the switch contacts are closed to the adjuster switch common circuit.
Both right side windows have a seperate power supply from the left side window's ,has RT DOORS circuit breaker CB1 - 25amp. location left instrument panel fuse block . Circuit breaker's very rarely fail .Do the door lock's work on that side of the vehicle ? The windows won't work with their own switche's ?
The DDS controls the passenger window through a GMLAN message to the PDS. When a power window switch is activated in the up or down positions the PDS supplies power and ground to the window motor control circuits to drive the window motor in the required direction. Prior to activating a power window motor the PDS will supply the control circuit with a low current bias voltage in order to determine that a short to ground condition does not exist, and during window motor operation the PDS continues to monitor the motor current to verify proper window motor operation. (Scan tool support is available for this system)
Check PDM fuse 4 15 amp ,this supply's B+ voltage to the DOORLOCK/WINDOW switch passenger side . Check for broken wires inside the flex boot from the body to the passenger door .
