Need three digit codes for sylvania TV for remote to the RCA digital converter box please help !!!?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
SOURCE: I have a RCA Digital
If you are able to access the internet, I would suggest try getting your question answered by searching online. Several sources have answers to your question. They may not be the solution, but worth a try. Who knows, one of them just might work. Most of the time, it just takes a little patience and plenty of persistence. Be willing to spend some time searching. You might start by typing into the search box exactly what you're looking for. Good Luck!
SOURCE: remote code for sylvania model 6419te
0062 0004 0009 0135 0189 0183 0227 0456 0008 0068 0075 0141 0161
