Vizio 42 in. LCD TV Logo
A
Anonymous Posted on Feb 01, 2016
"hi i have around a 3 inch wide shadow running down the left side of my VIZIO XVT3D424SV 42-Inch tv it only glitches when a brighter light moves thure it any ideas"
john cordey
Level 3:
  • Master 730 Answers
  • Posted on Feb 01, 2016
john cordey
Master
Level 3:
Answers
730
Questions
0
Helped
206286
Points
2287
Invertor tube needs replacing.
4 year old vizio 42 inch tv lcd. While watching tv, the screen started dimming. There is a 4 inch shadow all along left side of the screen and the 1 inch line shadow going down the middle of the screen.
Maybe a power supply or related issue but at 4 years of age the set has reached its life span----parts will be hard or impossible to find.
If you got four years I would retire it and recycle it and then replace it.
1helpful
Panasonic TC-P42S2 .. Transparent 2 inch wide vertical discoloration on panasonic 42 inch plasma, very left of the screen.
Fixed mine, myself! Black 3 inch vertical band (stripe) appeared after a cros country move on our PC-T50G10. Occasionally we would see white band with multicolored pixel width stripes. Took the risk of taking off the back to see if I could see anything. Found places on sides and bottoms where plastic like 2" flat cables could be seen. Guesstimated where the band was and found that I could flip down a black cover on one end of the cable. Tried to pull it, gently. Mistake. Realized it wouldn't one out like computer hard drive cables, so I took out the screws holding the plate on the other end (it's only an inch long). That allowed me remove the cable. Took it out, cleared away dust, put t back and closed the black over. It worked! Put the screws back in, back on and... we are happy (although I do have four extra screws!). Just be gentle.
1helpful
Why my tv power keep blinkin on and off VIZIO XVT3D424SV 42-Inch Full HD 3D
Because there is a failure in some module which the power or main board detects and refuses to power on.
The blink is a series of short blinks which report the error code - count them, report it and you may learn more.
It is worth saying that most of the times error codes do not help too much.
Having the TV , testing the power outputs and experimenting with disconnecting boards usually helps better.
Of course there are exceptions to both rules.
2helpful
2answers
I have a 37in. vizio flat screen. It has a black shadow in the left center of the screen. It's there at all times.It's about 7in.x 3/4in.it runs vertical.any ideas?
wish the news was better for you, the convergence chip or the color engine has faulted and burned the screen This will be an expensive repair unless it has extended warranty
Please rate my help++++Thanks for using FIXYA
1helpful
2answers
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
2answers
Hp r4252 white vertical stripe on left side, 5 in wide
Well sound as if a segment or Ic driver has failed on the panel. And a 42 inch replacment panel can run you $1250.00
3answers
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
6helpful
3answers
Ilo 42 inch Plasma TV
I have a Ilo 42 inch Plasma TV and it just stop playing, the power light comes on but the screen don't light up at all
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
