It's not a treadmill, it's a bike
SOURCE: Just taken delivery of new T9 treadmill the motor is not working
1) Adjust the reed switch , clean it, and tigh the wires connector
see the diagram
2) RUN the software calibration after you fix it, for diagnose, troubleshooting , fix it.
3) test the fuse for blown and replace, use the VOM, or c.breaker reset.
4)test the input voltage motor, with a VOM , if there are voltage, the motor need attention. tight any wires connector to the motor very well see the diagram
5) measure the output voltage board, for input voltage motor, if there are NOT voltage , the board is faulty. tight any wires connector for loose, or bad contacts. see the diagrama
IF doesnot resolve the problem call to the suppliers for warranty of the board of another parts, or service.
God bless you
ERR1
indicates a speed issue. In this case, the motor speed as reported
from the optic sensor differs
from
the speed setting.
Analysis:
Optic sensor signal issue -- Either the optic sensor signal is not
right, or it is read incorrectly, or
the
signal is not reaching the display.
test the speed sensor for open or faulty. clean it, and tight the connector very well. see the diagram attached. However RUN the software calibration for easy fix it.
God bless you
