Question about Nikon D60 Digital Camera
Why does body shear out, leaving the battery cover flapping about?
  • 1 more comment
  • VictoryBoy Jan 31, 2016
    Hi Ian Brunskill, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? I don't understand what you mean by "shears out" in your question. I have had a couple of D60's and have never had a problem with the battery or the little door.
  • Ian Brunskill
    Ian Brunskill Feb 01, 2016
    The problem is with the body of the camera, where the battery flap catch locates in the body when closed. On two occasions the body material has broken away so that the battery cover flap cannot lock into place
  • TC CAMERA REPAIR.Com Mar 24, 2016
    Sounds like you may need a new Bottom Cover put on the camera,
Locaation of the hydraulic roof reservoir on a audi a4 cabrio
BEHIND THE INNER COVER AT THE RIGHT OF THE TRUNK.U MUST TAKE OUT THE COVER..
1 - Flap for convertible roof compartment hinweis.gif Note
t The variable convertible roof compartment must be in the bottom position. t To remove flap for convertible roof compartment -1-, hinges -2- do not have to be removed. t Arrow points in direction of travel. q Bend flap for convertible roof compartment -1- on one side at hinge and disengage flap for convertible roof compartment -1- at hinges. q Fold down flap for convertible roof compartment -1-. q Disengage flap at hooks -4- (2x) by sliding it towards front. 2 - Hinge (2x) q Bend flap for convertible roof compartment -1- on one side at hinge and disengage flap for convertible roof compartment -1- at hinges. q Unscrew bolt -3-. q Disengage hinge -2- from body. 3 - Bolt (2x) 4 - Hook 5 - Variable convertible roof compartment
25573084-tnzdbwhiaswbtdy3r1p2vgzs-2-0.png THEN REMOVE THESE..
1 - Side trim (right-side) t Removing - Take out floor covering in luggage compartment. - Remove rear cross panel trim ? Chapter. - Remove trim for handle mounting ? Chapter. - Remove flap for convertible roof compartment ? Chapter. - Remove luggage compartment light ? Chapter. - Unfasten clip -2-. - Pull off side trim (right-side) -1- in direction of arrow. t Installing hinweis.gif Note
t Following installation, make sure seal is properly in position over trim. - Install trim in reverse order of removal. 2 - Clip
25573084-tnzdbwhiaswbtdy3r1p2vgzs-2-5.png UNDER THIS TRIM U WILL FIND THE MOTOR WITH THE TANK.USE HYDRAULIC OIL THAT U PUT AT THE STEERING RESERVOIR......BEWARE THE SAE OF THE OIL!!!!!
GOOD LUCK
Mar 15, 2015 | Audi A4 Cars & Trucks
Have a 1988 Acura Legend with a bad ignition switch...problem is how to get it apart to fix it. Can't get the bottom column cover off...any suggestions?
i think you meant Ignition switch.
really a 1988> no 1998?
the latter has air bags, and BOOM are very very dangerous.
yes, you are fiddling plastic covers. use a flash light.
covers, are you talking the steering column combo surround covers?
remove the screws , under under, do down, and look up, bingo?
i hope its a real 88,
i login to alldata.com
i look at lock removal.
7 steps, you are stuck at step 2
  1. Disconnect the negative battery cable.
  2. Remove the steering column lower cover. Disconnect the ignition switch wire connector from the dash fuse box.
  3. Insert the key and place on the 0 position.
  4. Remove the 2 screws and replace the base of the switch.
  1. To remove the lock, remove the steering wheel and the steering column covers.
  2. Center punch each of the shear bolts and drill their heads off with a 3/16 in. drill bit. Be careful not to damage the switch body when removing the shear head.
  3. Remove the shear bolts from the switch body.
end remove.
ask questions.
Sep 24, 2013 | 1988 Acura Legend
Changed battery in 02' candy and wont idle
you will need to take the negative cable back off and leave off while you are cleaning the throttle body.take the hose off going from air box to intake and take some carb or throttle body cleaner and spray on a rag and then open the flap on inside of throttle body and clean all of the build up out from around the flap.once you have it clean put the cable on and take it for a drive to let the computer relearn its value of the throttle position angle. i hope that this will help and let me know if i can help you any further........good luck let me know if you got it fixed cause this should take care of it it is a common problem.........
Jun 06, 2011 | 2002 Toyota Camry
Cleaned throttle body on hyundai santa fe now flap wont shut, sometimes it springs shut, is there somewhere i lube that part to shut?
check your cable to see if it is broken at the throttle body. they will overlap and make the butterfly stay open. hope this helps leave comment.
Feb 13, 2011 | Hyundai Santa Fe Cars & Trucks
Where do you place batteries in a wireless mini mouse
I have seen a couple of ways to get at the batteries on a wireless mouse. One is to look at the bottom to find a standard battery cover complete with a little finger slot that allows the plate to be lifted off from the bottom surface of the mouse.
The other is a sliding latch at the back of the bottom surface of the mouse body that releases the battery flap which then lifts upward. The flap is the backside skin of the top of the mouse.
Feb 08, 2011 | Dell U0636 Mouse
The cover of the battery compartment does not lock closed properly due to the fact that the front recess for the locking tab has snapped off, is it possible to replace the battery cover on this camera, the...
Hi Dear,
As described by you. Some part is snapped off. Is this part is a part of camera body or is it from the flap that opens and closes which holds the batteries.
If it is the flap, then it is possible to get it replaced. But if it is from the body, then also it is possible to get replaced the body, but in this case it will be an expensive business.
Please let us know if this suggestion was helpful in any respect.
We would love to serve you further if you require more information on it.
Have a nice day.
Nov 06, 2009 | Canon PowerShot S1 IS Digital Camera
How do i open the unit up to change the battery?
A small #6 torx screw driver is needed. The GPS flap on the back has to be opened. The antenna board has to be disconnected where the ribbon wire, covered with black tape, snaps onto the board. A small blade can flip the cable lock up and the ribbon wire will easily detach. Now you can remove the plastic flap, by pulling back the spring loaded hinge. Be careful not to let the spring fly out! Once the flap is removed, two screws are exposed on the top of the main body, same #6 torx. Once removed, use a plastic pry tool to slowly move along the circumference of the body. Once all the plastic snaps are un-snapped, be very careful when opening the **** shell you've created. You should now see everything you want to mess with.
Aug 12, 2009 | Garmin nuvi 670 GPS Receiver
I have a Fuji FinePix S5000 and the battery door catches (on the body of the camera) have broken off. Replace complete body assy??? I am sure mine is not the only one. any help appreciated.
I had this problem also (see below).
After getting poor results with the duct tape solution, I discovered another work-around. This should work whether it is chipped lugs on the door or on the body.
Firstly I used an old camera flash bracket that screws into the tripod socket, and this holds the battery door in place quite securely. However it was too long, so I cut and filed a piece of aluminium 25mm (1") wide by 2.5mm thick to the right length (around 100mm/4") and shape, and made a hole for the bracket screw.
End result is not exactly like new, but more functional than the duct tape and does not further damage the actual camera:
Mar 05, 2009 | Fuji FinePix S5000 Digital Camera
Motorola Razr V3 display problem
Solution this same thing happened to me - cause LCD screen going out = it's weak and thats the sign that it is giving up. To Temporiley to keep it on: take the battery out and back cover of battery off place phone in ICE section of Freezer ( NOT IN THE ICE )by the area where it gets cold leave it there for 10-minutes, then take it out after 10-minutes wipe everything up put the battery back on and restart phone & wah'la it's working....
Aug 14, 2007 | Motorola Mobility RAZR V3
Nikon D60 Digital Camera Logo
71 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
