Computers & Internet Logo
B
Bobby Harris Posted on Jan 31, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to reset passwords to factory default passwords
Jiri Sluka
Level 2:
Welcome Back:
Visited the website for 2 consecutive days.
  • Expert 20 Answers
  • Posted on Feb 13, 2016
Jiri Sluka
Expert
Level 2:
Welcome Back:
Answers
20
Questions
0
Helped
7238
Points
108
3 Related Answers
Anonymous
  • 113 Answers
  • Posted on Mar 14, 2007
SOURCE: cannot reset to factory default
Try hard reset Hold the reset button for a minute and while you are holding the button, also unplug the power cable from the back every 15 seconds. So, you would unplug the power 3 times and make sure, dont release the reset button even when the power is unplugged. This works for most of the SOHO routers. cheers
Computer hardware and networking support
  • 4281 Answers
  • Posted on Nov 22, 2009
SOURCE: default factory pass fails while cannot be reset
connect your router to computer with ethernet cable.
Then you can access it with following link.
for belkin routers http://192.168.15.1
for other routers
http://192.168.1.1
or
http://192.168.0.1
If you have problem in access router then you need to reset all settings to defaults then you can access it with above method.
For that press RESET button for 10 seconds it is in back panel of router.
Type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
pamthegreek
Pamela Bates
  • 149 Answers
  • Posted on Nov 28, 2009
SOURCE: Wireless light is not on
To restore the factory default configuration settings without knowing the administration password or IP address, you must use the Default Reset button on the rear panel of the router. 1. Press and hold the Default Reset button until the power light blinks on (about 10 seconds). 2. Release the Default Reset button and wait for the router to reboot. If the wireless router fails to restart or the power light continues to blink or turns solid amber, the unit may be defective. If the error persists, you might have a hardware problem and should contact technical support.
2helpful
7answers
Need password to my netgear router n 300
what is the model #?
Most netgear routers default to a username of "admin" and password is either " admin ", "password" or it is just blank. Those are the defaults unless someone changed it.
If you cant get in you can hold down the reset button on the back for 30 seconds (while it is plugged into power) and that will set it back to factory default settings then one of the above should work.
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
I lost my password to my netgear, to hook up my second computer?
You don't need a password to hook up a second computer - just plug it in. You only need the password if you want to change the configuration of the router.If that's the case, the default user ID for this model is 'Admin' and the default password is 'password'. If you have a non-default password you will have to reset the router to factory defaults and then login with the default ID/password.
To reset to factory defaults, press and hold the Reset button until the Test LED turns on (about 10 seconds). Release the Default Reset button and wait for the router to reboot
2helpful
2answers
How to retrieve forgotten password
hi there,just unplug it,then plug it back in,the password should be reset...
Please Rate max...appreciate it..
1helpful
2answers
I forgot my Password for NETGear WGT624 Please help
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
2answers
Default factory password
Most of the NETGEAR devices, except ReadyNAS products and Fully Managed switches, have the following default username and password:
  • Username = admin
  • Password = password
    • For older devices, password = 1234
If you have changed the default password and have forgotten it, you will need to reset the NETGEAR device to factory default settings in order to use the default username and password. Click here to learn how to reset the NETGEAR device to factory default settings. Please note: restoring a device to its factory default settings will erase any changes you have saved to the device.
This applies to:
  • Most of the NETGEAR devices such as routers and smart switches.
Aug 13, 2010 • Cell Phones
5answers
How do you reset a password?
Easy, reset the router itself, should have a tiny pin hole in the back that has a button that you must compress, just google reseting your model.
If you have any problems let me know.
3helpful
How do I reset a Xerox Phaser 4500 Centreware password to factory default.. or what is the factory default password? I have on which has been changed and nobody seems to know the PW anylonger
this should restore it to default.
By default there is no username or password required to access CentreWare Internet Services. If a username and password have been configured for CentreWare Internet Services and you do not remember the username and / or password, reset the printer to factory defaults (NVRAM reset).
To reset the NVRAM, go to the front panel's Main Menu:
  1. Select Troubleshooting, then press the OK button.
  2. Select Service Tools, then press the OK button.
  3. Select Reset NVRAM, press the OK button.
  4. Select Reset NVRAM and Reset Printer NOW, then press the OK button to reset all the settings to their factory default values.
3helpful
3answers
Forgot the password of my belkin router
Hold the Reset Button in, (You have to use a Pen Tip) for at least 5 seconds, that should reset router back to factory defaults.
2answers
Factory default
The following reset procedure will completely restore the default settings on the VDI-604 and VDI-624. Note: If you do not remember your password, you will have to reset the router to factory defaults. Step 1 Locate the reset pinhole on the back of the unit. Step 2 With the unit powered on, press and hold the Reset button. Step 3 Hold the Reset button for about 10 seconds. Step 4 Release the Reset button. Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting. Step 6 The device is now at factory defaults. Note: Do not recycle power during the reset procedure. VDI-604 firmware 1.05F/VDI-624 firmware 2.39DDM - The default username is admin and the default password is blank (nothing). VDI-604 firmware 1.07 Build 28/VDI-624 firmware 2.43 Build 12 - The default username is admin and the default password is password. Note: After resetting the router to factory defaults, you will need to contact Verizon to reconfigure your WAN settings.
2answers
Factory default
Grand Canyon Tech
Grand Canyon Tech
