Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
SOURCE: Need a remote code for a Durabrand DWT1304A TV
I bought the "3 in 1 easy to use" universal remote from Radio Shack for $5.99 and used the Durabrand Codes in the insert. It worked perfectly.
SOURCE: need tv code for durabrand 13" tv BH1304D
here are the codes for duraband, 1004, 1153, 1167, 1207 one of these will work if not or you need more help let me know!
SOURCE: durabrand tv model#BH2004D need code for GE universal remote
For the GE Universal Remote (RC24991-b), 0157 works (for me) with this Durabrand model
SOURCE: need codes and instructions for Radio Shack 3 in one remote programming
First, you need to realize that there is no such thing as a 'universal remote.'
At best, they are multi-brand remotes.
You might get lucky if you try any codes you have (or can retrieve from the Tandy website) if you check these brands too:
Funai, Symphonic, Sylvania, Emerson, Aventura, Durabrand, ESA, Magnavox, INSIGNIA, and Misakai
They are all made by Funai, one of the worst manufacturers in Asia.
