No water
Close the water supply to the machine and unscrew the hose from the machine rear, there is a fine filter screen to trap any foreign objects etc. if this is clean and your water supply is strong, you will need to replace the water inlet valve (solenoid valve).
Ie means inlet error
Check water hose and tap opened
Check if enough water pressure exists
By taking hose off from washing machine open tap
And check water pressure by visual .
If its ok then u got a small filter fitted where I put the water hose to be cleaned by a tooth brush .
If this fails them u got a damaged
Water valve Or electronic module .
IE error mostly means not filling completely with water or very slow fill
Hi
The "IE" error code indicates a problem with the
water inlet. The water supply valves are not turned on fully or the inlet hoses
are kinked, clogged or frozen. Remove kinks in the hoses and remove clogs with
a straightened coat hanger. If this does not resolve the problem, contact a
service technician.
Thanks for contacting fixya.com
Please do get back to us for further query.
