Question about Xitel Inport Pro Stereo To Pc Recording Kit Turn Your Lps Cassettes
When i open lp recorder i get message , lp recorder has terminated setting mixer controll (0047BB69) what can be done,
How do I flip from cd and dvd's in recordings and transfer to then from vinyl's
sorry I don't know!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Nov 12, 2014 | Xitel INport Deluxe
LP recorder incompatibility
The software (LP recorder) does not recognise your soundcard. Download a different free program to record your LPs.
Dec 19, 2013 | Xitel INport Deluxe for PC
0047BB69 with the LP Recorder
This is not a solution. i have just discovered that I have exactly the same problem.
Nov 06, 2013 | Xitel INport (HFLI1X1) Audio Input
Recording levels are low
There's no record level adjustment on the Masterlink. Increase the output level of your mixer, or add a variable level preamplifier between the mixer and the Masterlink.
Or, use the level adjustment on the Masterlink once the recording has been done, and before you write it to CD, either with level control or DSP normalisation
May 23, 2013 | Alesis MasterLink ML-9600
Why does my camera stop recording after one hour? i need to record 90 minutes
Your camera records in two modes: SP and LP modes. SP is a higher quality mode that runs for about 60 minutes, while LP records for 90.
To change to LP mode, open the menu and select [VCR setup]. Select [REC MODE], set it to [LP] and close the menu.
Keep in mind that your video and audio will be of noticeably lower quality with this setting applied.
Mar 08, 2011 | Canon ZR200 Mini DV Digital Camcorder
I am running Windows 7 with Audacity and a Samson CO1U USB mike The mike is recognised in Windows and have set Audacity for the Samson input and adjusted input level. The sound recorded is very...
Did you try opening the sound properties page in the control panel...look for the recording tab in sound properties..here you will find sliders for the inputs on the sound card(as for recording)..you may need to set these up also to make everything work properly...there also should be a sound mixer built in to windowsthat you can access by clicking the speaker icon on lower right side of screen(if you have icons enabled)..right click this to open and when you get to the mixer there should be a tab at the top for advanced controls..here you will find the recording controls..make sure the input is turned up and make sure the input in not muted..there should be a box for mute and it should not be check marked
Jan 21, 2011 | Samson C01U Consumer Microphone
"Cant' find audio output mixer line for Line (USB Audio)(0047C6C0
I got this error when first running version 5 on Windows 7. So I tried running it in Windows XP SP3 compatibility mode, which solved it for me.
May 31, 2010 | Xitel INport (HFLI1X1) Audio Input
I plugged a mic to my dell laptop but it isnt working, do i need a sound card?
No, if you have a jack to plug the mic into you have a soundcard. However the mic is probably muted in the mixer software. Go to the control panel, left click on sounds and audio, then click on the advanced button; this should open the mixer in the play back mode, at the top left of the mixer go to options and select properties, a new page will come up with a radio button showing playback or recording, switch the radio button to the recording list and check everything in the checkboxes including the mic and press ok. A new mixer should come up with your recording deviced, from here you can set your microphone device volume.
Jul 01, 2009 | Computers & Internet
Home stereo audio problems
Could be a bad patch cord, a setting on the mixer, a faulty mixer (unless it works ok with other amps), or a dirty control on the Sony amp if it has analog controls. Have you tried connecting other sources to the Sony?
Sep 27, 2008 | Audio Players & Recorders
No output mixer settings
u need dj card hi tech stuf fnot sb lol ok go to guitar center get you self a in and out box usb midi ok has quder in in jacks for record players cd and software they make a dj labtop card also dual inputs hi tech gear not stander sb stuff ok tascam makes sum alot compains that do u wann wann run record player son to dj on with cool effects mensu ? try tractor software maby for lp and a nice in and out box ok
Jan 15, 2008 | Creative Labs Sound Blaster Live! 24-bit...
Xitel Inport Pro Stereo To Pc Recording Kit Turn Your Lps Cassettes Logo
613 people viewed this question
Top Xitel Video Cameras Experts
Marvin
Marvin
Are you a Xitel Video Camera Expert? Answer questions, earn points and help others
