Coffee Makers & Espresso Machines Logo
V
Vera Roth Posted on Jan 30, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No power no light
Brewer worked yesterday today no light no power tried another plug in no luck how can i ifix my problem?????
L Pfaff
Level 3:
Top Expert:
  • Master 11,573 Answers
  • Posted on Jan 30, 2016
L Pfaff
Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3585319
Points
181713
Check cord for damage, while plugged try wiggling wire in different locations and watch for power, if you see power replace cord, if no power replace machine
press the helpful button and check links below
Drip Coffee Maker Problems HowStuffWorks
How to Repair Coffee Maker How to Repair Small Appliances Tips and...
Coffee Maker Repair How to Repair Small Appliances
Light is on where the electrical cord is plugged in but cannot turn computer on
Hard to say exactly what is wrong with the limited information you provided but...
It's fairly common for laptops to get stuck is "Sleep Mode" and exhibit this behavior.
If that's the problem, you can try the following...
Unplug the power adapter from the computer, remove the battery from the computer, then press the startup button for a few seconds. Without putting the battery back in, connect the power adapter and try starting the computer again. If this works, shutdown the computer, put the battery back in, and you should be back in operation.
Good Luck!
No lights. dead. checked plug
Unplug the brewer. Turn it upside down. You may need to use a small screwdriver to remove small rubber pads that cover screws that hold the bottom cover to the brewer body. Remove those screws. Using a volt-ohm meter, check to see if you have power coming from the power cord to the brewer at the points on the circuit board. IF NOT, REPLACE THE POWER CORD ( cheap fix). If the power cord is working, when you take off the bottom cover and you will find a small circuit board that has very small switches that actuate the brewer. Take that circuit board off, and with a toothbrush and water/soap solution, gently clean the circuit board and then let it dry completely. CHECK the board to see if their are any burnt areas, or any deposits that are corroding connections, and check to see if all connections are unbroken. Fix anything with a small soldering iron that has separated. Let the circuit board dry in the sunlight, and then replace it and the wires connected to it. Try then to plug the cord in and turn the brewer on to see if the lights work then. IF NOT, you will have to replace the circuit board.
2helpful
Samsung Silvercare Front loader working fine yesterday. Today there is no lights to the dial. There is power to the cord.
Try unplugging the unit for a few minutes. After plugging it back in and the power still doesn't come on, you will need to replace the control board.
It worked yesterday, but today it just says "NOT
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Worked yesterday and nothing the today. Absolutely no power. Something is open the circuitry. But what?
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
3helpful
NO power in subwoofer, power light will suddenly not turn on.
I got the same problem yesterday. I just unplugged the power from the subwoofer, then plugged today. Now the lights stayed a little longer then yesterday, but goes out again a little later. So I just unplugged and wait ultil tomorrow then I'll try again.
1helpful
2answers
Fujitsu Siemens Scaleo 600. No power to processor.
Probably a PSU failure, although it could just be your power switch. Try shorting the power switch connections on the motherboard, if that doesn't work, replace the PSU with a standard ATX PSU. They're relatively cheap.
Will not power on
First try disconnecting ALL power to the laptop - not just at switching off at the wall but pull the plug and remove the battery as well. leave it for 30 seconds or so and put it all back and try again.
If no luck then press F8 on boot until the boot options screen appears and select 'Last Known Configuration'
If no luck then is this XP or Vista?
D-Link DI-624 Airplus Extreme G - No power
The power adapter was the problem. Just changed it and everything is back to normal.
My computer its not working is off
try and plug in your charger and then put it on. it is obvious your battery is low. and if you left it on with the power plug on, try and replug it now if the light did not come on then there is possibility that your power pack is bad. then you have to change it. good luck
Top Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
