Replaced DLP chip and reconnected all of the cables
SOURCE: Yellow blinking status light
I would make sure you have it seated correctly into the ballest some times the connector will come undun
SOURCE: green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
http://servicemanuals.vstore.ca/
SOURCE: yellow status light blinking
tour air filter cover door is either not tight, or off, or the small switch behind it is bad. it is on the side opposite the ac plug.
SOURCE: Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
SOURCE: mitsubishi 62" dlp wd-62525
The lamp is either defective, not connected properly to the wiring or plugs (careful alignment required on the two connections), wrong type bulb, or the front panel is not replaced properly to trigger the panel sense switch (lower right side of panel)
