Cars & Trucks Logo
Bruce Cambell Posted on Jan 30, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replaced roof dvd players side bulbs lights in kia sedona 07 plate now they only work when switched not automatically when door opens?
Claude Kayser
Level 3:
Top Expert:
  • Kia Master 9,098 Answers
  • Posted on Jan 30, 2016
Claude Kayser
Kia Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067014
Points
28436
Kia Carnival & Sedona Forum [Archive] - Kia Forum - Kia-Forums.com
www.kia-forums.com > Kia Forum > KIA Models
Jul 8, 2006 - [Archive] Discussion area for every generation Kia Carnival and Kia Sedona. ... 2006 SEDONA EX front and rear blowers dead · 2007 Kia Sedona LX 3.8L... out of the intercooler air intake · 2002 Kia Sedona Front heater will only work with a slap! ... 2003 Kia Sedona, Will Crank but not start after replacing MAF, crank and ... Kia Carnival & Sedona 2006+ [Archive] - Page 3 - Kia Forum
Apr 11, 2012
Kia Carnival & Sedona (2002 - 2005) [Archive] - Page 5 - Kia Forum
Jul 24, 2008
Kia Carens & Rondo Forum [Archive] - Page 2 - Kia Forum - Kia ...
Aug 15, 2007
More results from www.kia-forums.com
[PDF]2006 Sedona Owner's Manual - Kia Canada
www.kia.ca/.../ownersmanual/2006_sedona_Owners_Manual_E... Kia Motorsrecommended special tools, genuine Kia replacement parts and .... Room light main control switch.....3-123 ...... work properly, the power sliding door and ..... fuel only. • Check to make sure the fuel filler cap is securely closed after refu- .... roof, you have to reset your sunroof sys- ...... bulb check when you turned the ignition.
L Pfaff
Level 3:
Top Expert:
  • Kia Master 11,573 Answers
L Pfaff
Kia Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3587339
Points
181713
5 Related Answers
Anonymous
  • Posted on Dec 31, 2008
SOURCE: how do you change the right front headlight bulb on a kia sedona
Remove the headlight assembly. Just remove the 3 bolts with a 10 mm socket and pull it out so you can disconect the wire harness. After that pull the whole assembly out and unscrew the bulb cover. The bulb is held in with a spring clip.
Anonymous
  • 1986 Answers
  • Posted on Sep 15, 2009
SOURCE: kia sedona outside door handle replacement
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Pull back the weather seal and you'll be able to get to remove the bolts securing the outer handle on
Anonymous
  • 91 Answers
  • Posted on Dec 31, 2009
SOURCE: DOOR HANDLE PIN HOLD LOST
remove the door cards and the plastic sheeting. you can get to the handles from here. i used a piece of copper welding rod with the top bent over. worked a treat
Anonymous
  • 20 Answers
  • Posted on Jan 30, 2010
SOURCE: 2007 Kia Sedona van power sliding door
i just had to have this fixed on my 07 sedona on the bottom arm for the doors there are litle lock solinoids that go bad i would take it to a dealer to have it checked for the switch you can turn the power off to the doors and open them manualy but they are hard to open because you are pulling the cable instead of the motor doing it and this will not hurt the doors
Anonymous
  • 179 Answers
  • Posted on Apr 03, 2010
SOURCE: how to change the headlight bulb on the passenger
open bonnet remove 10mm bolts securing headlight
pull forward and remove bulb
Rear running lights not working on right side brake lights work ,when pressing brake. for a 2006 kia sedona
Dual filament bulb most likely..... one of the elements in the bulb burnt out. Try replacing the bulb first.
Kia dvd player
Is there power to it?
2007 Kia Sedona Automatic Driver Side Slidding Door troubleshoot guide
motor -fuse - motor drive . You will have to do preliminary checks to determine which it is.
2answers
2003 Kia Sedona replaced low beam bulbs checked fuses still won't work high beams n fog lights work can u help
IF THERE IS NO POWER AT EITHER LOW BEAM LIGHT SOCKET & YOU ARE SURE ABOUT THE FUSES, SWAP THE WORKING HIGH BEAM BULBS WITH THE LOW. IF THAT DOESN'T DO IT YOU NEED TO REPAIR OR REPLACE THE BEAM SELECT SWITCH, { DIMMER SWITCH } KNOWN AS THE COMBINATION SWITCH, UNDER THE STEERING WHEEL. CAN USUALLY BE DONE WITHOUT PULLING THE STEERING WHEEL. TEST BEFORE BUYING, MAY BE COSTLY. GOOD LUCK , DR.VOLT
How do you replace the low beam head light of Kia Sedona 2007
hey i have a sedona 07 and it just hapen to my i dont know if theres a esear way of doin it but i pull the hea light out you ondue 2 screws on top of the light pulls out make sure you dont touch the new bulb( the glass) also you only find it at the dealer chip its only 18 dollars,.
1helpful
2answers
2005 kia sedona low beam headlight's don't work
CHECK THE BULBS, YOU MAY NEED TO REPLACE THEM, ALTHOUGH IT WOULD BE ODD THAT BOTH LOW BEAM SIDES OF THE BULBS WOULD BE BAD, ALSO CHECK YOUR FUSE BOX AND LOOK FOR THE LOW BEAM FUSE, MY SEDONA HAS ONE, YOURS MIGHT HAVE FUSED OUT
1helpful
Off the track
Unsure if this is specifically related to your actual problem but there is a TSB on the side door sliders for 2004, I had mine replaced under warranty.
Service Bulletin Number: 82 NHTSA Number: 10015268 Model Years Affected: 2002, 2003, 2004, 2005 Date of Bulletin: 07/2005 Bulletin Summary: IMPROVED CENTER SLIDING DOOR ROLLER ASSEMBLY.
7helpful
Top Kia Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Kia Expert? Answer questions, earn points and help others
