I have been told the fan may need replacing. If so, how can I do that. I did try the red button press method with no results.
SOURCE: PS3 locks up when I try to load a PS2 game
If you have a 40GB it has absolutely NO backwards compadability with PS2.
SOURCE: PS3 freezing when trying to quit ps2 games
it may because your psp3 has been on way to long and is over heating.
SOURCE: game freezes when 'ps' button is pressed
perhaps your ps3 need a firmware update...enter in sony official website and download your ps3 latest firmware...check if your ps3 hdd is ok...bad hdd´s can cause game freeze...
SOURCE: the mem stick game goes off and the psp freezes!
there are two remedies for this problem 1st is your not using a firmware attached to this games .these are 6.00 firmware games so try to install 6.00 firmware and look iam sure the game will work,if your using custom firmware upgrade to 5.0 gen d2 and it will be ok 100% sure sometimes the games are patched to run in a firmware inferior than 6.00 so it will not play on 6.00 try downloading a non patched version (although i dont trust this remedy) if you think that i had spent sometime for your problem and did this for your sake rate this helpful and rate this helped you
Testimonial: "thanx 4 ur advice!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! it really worked!!"
