It's possible that the T-Con board or the screen is damaged, but it's difficult to say without further testing. However, based on the symptoms you've described, it sounds more likely that the screen is damaged. Covering a pin on the ribbon cable from the T-Con board to the screen driver board is not a typical solution for this kind of issue, and the solarized colors you're seeing are indicative of a damaged screen.
If you have the necessary technical knowledge and equipment, you could try swapping the T-Con board and see if that fixes the issue. However, replacing the T-Con board is not guaranteed to solve the problem and may not be worth the cost and effort if the screen is indeed damaged.
In general, handling a flat-screen TV can be delicate and cause damage, especially if proper precautions are not taken. It's possible that you damaged the screen while replacing the backlight strips. To avoid further damage, it may be best to seek professional assistance if you're not confident in your ability to repair the TV.
If you received a good main and t-con, cables and plugs are good, there isn't anything left other than a panel issue. Try unhooking one flat ribbon cable at a time and see if you get half a picture.
First try to gently push the cable between the main board and the LCD controller (T-CON) board and if that doesn't affect the image then replace the T-con board.
Take ur hand and pushes all around the tv frame bazel see if the veritical blue line react like flashes or lighter or darker,than this tv can not be repair at all because the LCD screen itself it is the caused,the LCD screen cost same as a new tv if it is require to be replace.If there are no reaction of the blue line at all than ur tv have a circuit board problem.The T-CON board is dying,this board sit in the middle bottom of the LCD screen,must be replaced will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a new refurbish T-Con board for the replacement.
It sounds like your backlight is out or barely functioning. Try replacing the inverter board(s). Since you can see a picture, the T-Con board is probably okay.
The board that called the T-Con board it is could be dead.This T-Con board control the out put tv signal to the tv LCD screen panel.This T-Con board sit at the bottom in the middle bottom of the tv LCD screen panel. Take the connection out of the T-Con board .Tries clean the connection of the board with some rubbing alcohol,might fixed the problems,if not.Tries websites like Shopjimmy.com,EBay.com to buy a refurbish T-Con board for the replacement.
The screen flicker than go blank,does it still have power to the tv set?Yes,than this cause only can be causes by only 2 boards in the tv can causes this problems,if tv power still stable for the set.The T-CON board it shorting out and dying for this problems to happen or worst case causes the Main board tv Tuner signal board it dying.The T-CON board the priced it is cheaper and could cause this problems too.Tries change this T-CON board first,see what happen.This board T-CON board sit at the bottom in the middle of the LCD screen panel to decodes pictures pixel before it go onto the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
The blue line came on to the tv LCD screen panel by itself,not caues by u or an object by hitting the tv LCD screen panel itself wright,if yes this problems can't be repair because the LCD screen panel itself dead.Blue line happen by itself,the tv board that call the T-CON board it is dying and the causes.This T-CON board sit at the bottom in the middle of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacemrnt.
This tv have a problems with a board that call T-CON decodering board.This T-CON decodering board sit at the bottom in the middle of the LCD screen panel.This T-CON decodering board,decodering the tv incomming broadcasting tv signal before it go into the tv LCD screen panel to produce pictures.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.
