Hi Edna Merrill, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Have you tried to backup your ipad and restore it from restore it from iTunes.Hi Edna Merrill, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Have you tried to backup your ipad and restore it from restore it from iTunes.
You can't post conmments that contain an email address.
Google Play Services, the preinstalled app on your phone plays an extremely crucial role in the regular running of your lenvono. If anything is wrong with it, then your lenovo will start throwing fits in the form of errors and crashes including 'Google Play Services keeps stopping' error.
To remove the error, you need to fix Play Services. Here you will find numerous ways to fix any issue related to Play Services. Let's get to know them.
1 Starting with, will actually with restarting you Lenovo.
2 Another that does wonders for any issue is to "clear the cache" and date of the particular app. In this case, we need to clear cache and data for "Google Play Services" and "Google Play Store".
Doing any of that will not delete any data from your phone. However, clearing data will log you out from Play Store and reset its settings. In settings
3 "Google Play Services" is a system app, you cannot remove it from your lenovo completely. However, you can uninstall the updates, which will revert it to the factory version forcing your phone to update it automatically, thus fixing any issue.
On the Google Play Services screen, tap on the "three-dot" icon at the top-right corner. Select Uninstall updates from the menu.
4 Unlike other installed apps, you don't have to update Google Play Services manually. It's done automatically in the background by your lenovo.
However, sometimes, the issue is with the update itself. So you need to update it to the newer or older version manually. We have covered ots of ways to update google play service in detail. Do check that. And if you face any issue while updating it, check fixes.
6 Similar to restart, sometimes booting in the safe mode fixes various issues on an Android phone. Again, doing that will not delete you data and you can access it in safe mode as well. Running the lenovo in safe mode also helps in identifying the issues caused by the third-party apps.
I hope these will get you over your issue with ease.
u may after update google services go to google play store go to my apps go down to google services press on thatat and it should say uninstall or update go to update and let update and it should work then when its updated
There could be several reasons why your Verizon tablet keeps disconnecting from Wi-Fi and not accepting your password to reconnect. Here are some possible solutions:
Restart your tablet and your Wi-Fi router: Sometimes, simply restarting your tablet and router can help resolve connectivity issues.
Check your Wi-Fi signal strength: Weak Wi-Fi signal strength can cause frequent disconnections. Move closer to the router or try to improve the signal strength by repositioning the router or using a Wi-Fi signal booster.
Check your Wi-Fi network settings: Check if your Wi-Fi network settings match those of your router. Make sure you have the correct security settings and password. Try to forget the network and then reconnect and re-enter your password.
Clear your tablet's cache: Clearing your tablet's cache can sometimes help with connectivity issues. You can do this by going to Settings > Storage > Cached data > Clear cached data.
Check for software updates: Make sure that your tablet is running the latest software updates. Check for updates in Settings > System updates.
Factory reset: As a last resort, you can try doing a factory reset on your tablet. This will erase all data on the tablet, so make sure to back up any important files before doing this. Go to Settings > Backup & reset > Factory data reset.
If none of these solutions work, you may want to contact Verizon customer support for further assistance.
southerntelecom.com/polaroidsupport/ has instructions and downloads for flashing the firmware. that's the most serious factory reset possible. I've used their firmware and livesuite software to flash my pmid10c back to stock after I disliked the OTA update I let install.
Had same problem when I installed new dsl router/modem.Tap settings ,tap genaeral,bottom of page tap reset,then tap reset network settings.Ipad will reset network and restart.You will have to then go back to set up network again and reenter password if set.Worked for me.
You have not mentioned whether it is not working at your home or on other networks as well, some forums say that some ISPs do not offer this service (but I have my doubts, about this).
What I would try is go to "reset
network settings" on your ipad. So go to "Settings",
"General", "Reset", then "Reset Network Settings". After you do this,
you will need to re-enter your wireless network's password. Hope this helps
Hey,
I believe there should be a tiny reset button in the back, which you'll have to press for 15 seconds using a paper clip. This will reset the ENTIRE configuration of the network, so it will reset with the DEFAULT username and password, which you might have to call D-Link if you don't have the information.
There's more information on that over here: http://www22.verizon.com/residentialhelp/fiosinternet/networking/troubleshooting/questionsone/86195.htm
Just a note: it might not necessarily be the router's fault because I've heard that many people had problems with their iPad's wireless network after they updated to the newest firmware, which is 4.3.3. So, if you don't want to do mess around with your router, you can either wait for a new software update, or downgrade it, if you have the necessary files.
Good luck,
-virjog
