possibly the learning curve of the new computer. you must drive the vehicle around in certain conditions based on manufacturers specs. drive the vehicle for about a half hour some wide open throttle for a few where allowable and steady highway speed as well. theres a learning curve as called that the computer must go through in order to calibrate the engine.
ECM Learning Curve Dodge Cummins Diesel Forumecm learning curve Google Search
theres an example.
Is this a 4-in1 convertible crib? The Toddler bed will need the bottom railing and a half rail to convert from a crib to a toddler bed. The half rail can also be removed to make the 4th conversion to a toddler bed with out railing. But to convert this specific bed you DO have to add the bottom rail that came with the bed at purchase.
I can't offer the exact answer, but hopefully my suggestions will be helpful...
Converting the crib to a full-size bed should actually be a fairly simple process of detaching the 4 sides that make the crib, and replacing the 2 short sides with the full-size bed rails that were sold separately in a conversion kit. The 2 long sides of the crib become the headboard and footboard of the full-size bed.
Unfortunately, it's only a simple process if you already have the full-size conversion kit bed rails. And since Morigeau-Lepine went out of business, they aren't making any more conversion kits. If you don't have the full-size bed rails, then this could be quite difficult.
It's possible that some stores that used to sell Morigeau-Lepine cribs might still have a conversion kit hidden somewhere in the back of their stock room or warehouse. You could try calling around to a few of your local stores to ask if they would check for you. It's a long shot, but it doesn't hurt to ask.
If you have the rails, or are lucky enough to find them, then it should be as simple as locating the screws that hold the crib sides together, removing them (most likely with an appropriatly sized hex-key,) and putting the screws back through the headboard and footboard into the bed rails. (I'm really just assuming that it works the same as the Babi Italia conversion.) If no screws are visible, or if removing them doesn't detach the crib sides, then they are probably also held together with locking bed rail fasteners. To release the fasteners, remove any visible screws, then push upwards on the short side rail while pushing down on the long side rail. You might have to tap the rail up with a rubber mallot to get it moving.
If you don't have the full-size bed rails, and you can't find them anywhere, your only option may be to build them yourself, or find a woodworker to build them for you. Search online for "Bed Rail Fasteners" and you'll see several options for hardware, but they might require modifying the headboard and footboard as well. Full-size matresses are 75 inches long, so you'll want the length of your rails to accomodate (ours are 77 inches long.)
If you have it on the lowest setting already, that's as low as it can go. If you have wheels (which I don't think yours does) you could remove them to lower it a bit more. If it comes with a wood toddler rail to keep her from falling out, I would use that. If it doesn't, you can pick a metal/mesh one up at any baby store in various lengths. You could also put pillows or stuffed animals on the floor to break her fall. Another helpful tip for when she is a bit older and no longer has a toddler rail, you can slip a pool noodle under the sheet to prevent simple rolling out of bed. Hope this helps.
I have the same crib and it can be transformed into a toddler bed by removing the front rail and it can be transformed into a full size bed using a full size bed frame and the front and back rails of the crib.
Make sure the mattress support in in lowest position. Remove the front top rail and front panel. Attach both safety rails ( small side pieces) to the crib end leg using the safety rail bolts.
All you have to do is remove the plastic slider rails on the top and bottom of the front rail and take off the rail. This bed still has 3 rails like a daybed when it is changed into a toddler bed.
They do have answers on their website, you may want to check your printed or online crib instructions to remind yourself how you put the crib together, too.
I found the answers here: http://www.pali-design.com/index.php?path=customer_services&template=faq§ion=customer_services&subsection=faq&page=faq
i've pasted them below. You can make it a toddler bed without a side rail just by removing the movable side of your crib, and you can install the side rail instead of the movable side if you want it to look a little more finished and help keep your child from rolling out of the bed.
FAQ
How to convert a crib into a toddler bed To
convert a crib into a toddler bed you must loosen the two front gold
bolts left and right side of the crib and remove the dropside (the
front gate that goes up and down). After removing the dropside be very
careful that you tighten back your two gold bolts.
How to install the streight rail (toddler rail) To install a streight (toddler) rail
loosen the two front gold bolts left and right side of the crib and
remove the dropside, once you have removed the dropside replace with
the streight rail. Always be very careful and make sure you tighten
back your two gold bolts in the front.
1-Lower drop side to lower position. Then on the opposite side of the crib, remove stationary side. To remove stationary side, press the small tab on the end hardware(brown plastic piece that connects the rail to the frame) and then pull rail up.
2-Before reinstalling the conversion safety rail(csr), remove the mattress support bolt that is on the side the the csr opening will be(the foot of the bed). A new bolt will be used to reattach the mattress support in the next step.
3-Slide csr hardware onto the hardware on the crib ends. Insert two 1/4-20x2" bolts into each end. One bolt will replace the mattress support removed in step 2. Be sure to put the bolt back through the mattress support bracket before screwing into the end.
I have the instruction page with pictures if you would like a copy emailed. [email protected]
