Nikon D5200 DSLR 18-55mm Lens Kit with Camera Accessory Kit - - Logo
o
omar hussein agha Posted on Jan 29, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My camera won't turn On - Nikon D5200 DSLR 18-55mm Lens Kit with Camera Accessory Kit - -
L Pfaff
Level 3:
Top Expert:
  • Nikon Master 11,573 Answers
  • Posted on Jan 29, 2016
L Pfaff
Nikon Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3583902
Points
181713
Need new battery
Testimonial: "didn't work"
  • L Pfaff
    L Pfaff Jan 29, 2016
    Sorry that did not help, 4 more things to try 1) remove and replace battery 20 times, to try and establish a good contact.
    2)hold on off button 15 seconds,try a few times
    3) repeatedly, press button quickly like your stabbing it.
    4) not to forcibly, but sharply knock the camera against something solid a few times like counter top.
Camera won t turn on
What model Vivitar camera? What type(s) of batteries?
Fujifilm xp30 that won't turn on.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
My Lumix DMC-LX5 camera won't turn on
1helpful
Canon powershot SD1300 IS won't turn on, even with fully charged battery
1helpful
I dropped my canon powershot SD 4500 IS and now it won't turn on! It's survived countless other falls just fine, and would turn on immediately then. All times, including this time, have been when...
Really!....you've dropped your camera "countless" other times and now you're concerned because this time, it won't turn on!!! You're not sure what else to do?!!! How about not dropping your camera. How about using the wrist strap. Your dropping luck has run out...your camera does not have nine lives.
My camera will not turn on even after charging it for a long time. The battery works in other cameras except mine so the battery is not the problem. Why will my camera not turn on?
My camera won't turn on and the lens won't close
Perhaps you have bad batteries? Connect it to another power source such as an AC wall outlet and use your power adapter and see if this helps. If it does not or you have already tried this then your camera may need to be serviced.
Top Nikon Video Cameras Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Nikon Video Camera Expert? Answer questions, earn points and help others
