TDK-NX-4CD 'OPEN/CLOSE' button does not function
SOURCE: CD door will not open. Does not respond to the open close button.
the cd drive should have a tiny hole under the drawer. push a small screwdriver into the hole and it will release the drawer.
SOURCE: My KLH DA1302 5-Disc CD Changer door will not open or close.
Hi: Im Ronald Marts in January 2008 I posted a problem with my KLH DA1302 5-Disc CD Changer,it is still posted on this website on the details of my problem I found that with the top off the door will not open or close, the disc will spin but thats all. After checking all wiring, screws for looseness I gave up and put the top on, being frustrated I foregot to unplug the machine before putting the top on. I put my hand on the top in front of the machine to put in the screws on the back, in the meantime my wife pressed the open- close button and it worked, when I took my hand off it quit working, there is a metalic metal strip on the inside of the top in front that has to make contact to the components inside to solve this problem I put two pieces of wood wrapped up in a wash cloth and wedged them on top of the machine and the cabinet it is kept in one on each side towards the front I know It sounds crazy but it works and my wife is estatic, she likes to listen to her CD,s with her cordless ear phones when she does things around the house. I hope this has helped you all with this problem.
SOURCE: CD Discs have been displaced inside the unit while moving
Had this happen to me awhile back while I was fixing a DVD scratch problem with my 400 changer. As I recall, the top cover comes off easily (a few side and back screws and perhaps an internal top try cover) and you can access the disks easily to reset them in their slots. Obviously, you should unplug the unit before you open it.
SOURCE: Denon CD player DCD 920. When using the
Off the power, and plug off the switch, and try opening it manually. DO NOT force open it. I don't think it would close back since it has no electricity already.
SOURCE: Both Cd trays won\'t open in this unit. When
This seems like a very big issue. Try contacting Denon for a solution.
