Heater only blows cold air
The keepers of the actuator have broken or fallen off of the actuators lever which is under the dash on the drivers side. the actuator and keepers is a cheap part to repace but getting to it under the dash is not that easy, its a common problem in the kia amantis. when i had a fender bender it caused the pins or keepers of the actuator to fall or break off, and instantly my drivers side only blew cold air until i was able to get to it behind my dash and replace it.
SOURCE: heater blows cool air. temp. gauge stays on cold
heart core is plugged or more thremostae is stuck in the opened position. the A/C will always come on during defrost that is how it works on all cars.
SOURCE: heater blows cold air
Sounds like the cooling system is low on antifreeze. Have you checked to make sure it is at it's proper level?
Testimonial: "yes we add 1 gallon antifreeze and it works fine when we are actually driving it, however when sitting at stop light or in a parking lot not moving, it starts blowing cold"
HEATER NOT
BLOWING COLD,NO HOT AIR FROM HEATER,A/C BLOWS HOT AIR,A/C NOT BLOWING COLD,
COLD AIR FROM HEATER,BLEND DOOR ACUTATOR CLOSED,HVAC UNIT NOT OPERATING,
http://alltypesofpartsreplacing.blogspot.com/2012/12/heater-not-blowing-coldno-hot-air-from.html
HEATER NOT
To troubleshoot this types of problem,click the link below
:----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the
issue.
Engine Overheats and heater
blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers
side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
This will help.Thanks.
