Washing Machines Logo
Narell Humphrey Posted on Jan 28, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GE GFWS3500LOWW not starting on any cycle
My GE GFWS3500LOWW front load washer is not coming on regardless of any cycle that it is put on. It just locks the door and after about 10-15 seconds it unlocks and the start button pauses and blinks. Also i am trying to put it in service mode by using the following steps: 1. Press the power button and ensure the display is off. 2. Disconnect the power button and wait 30 seconds and reconnect power cord. 3. Press Signal-Delay-Signal-Delay. After i followed these steps about 5 times nothing happens. I even tried Signal-Extra Rinse-Signal-Extra Rinse and still nothing. I checked the pump strainer below and also the intake strainers and all are clean.
JEREMY RAGAN
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 21, 2018
JEREMY RAGAN
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1440
Points
6
I am having the same issue with mine. did you ever figure out what your issue was?
Claude Kayser
Level 3:
Top Expert:
  • GE Master 9,098 Answers
  • Posted on Jan 28, 2016
Claude Kayser
GE Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5066534
Points
28436
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Testimonial: "the door latches because i am unable to open when it latches. when i press start on any cycle it just locks the door, nothing happens and after a few seconds it pauses and unlocks the door"
  • 2 more comments
  • Narell Humphrey
    Narell Humphrey Jan 28, 2016
  • Claude Kayser
    Claude Kayser Jan 28, 2016
    It could be the door sensor.
  • Narell Humphrey
    Narell Humphrey Jan 29, 2016
    i opened the door and manually pressed the sensor and it locks the door..when i take my hand off the sensor it pauses
  • Claude Kayser
    Claude Kayser Jan 29, 2016
    Electrolux red led flashes 10 times Washing Machines ...
    www.fixya.com › ... › red led flashes 10 times › Washing Machines
    Electrolux washing machines red led flashes 10 times related questions and ... Hi my Zanussi washing machine model zwf1437 only has the power led and door led on. ... I've replaced the door lock mechanism but get the same problem - End light ... times and the door is unlocked and the start/pause button flashes green.
My 4 year old front load GE washer won't go to the
is there water left in the lower area below the lower wash arm?if so maybe the bottom sump is blocked by food debris or the pump and or sump is blocked by food debris shutting the unit off earlier than the cycle says,find the tech sheet and run the diagnostics for the entire cycle,its normally in the lower area below the door in this panel on one of the side walls in an envelope
2helpful
3answers
There is a musty oder coming from inside washing machine.
Dump in a gallon of white vinegar, fill with water, highest setting, after it goes through that setting, turn it off and let it set in the washer for about 30 minutes (use hot water).
Then put it on another wash cycle and then go to the rinse and spin. This should remove the order, and you should leave the door open when not in use.
Good Luck
1helpful
2answers
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
1helpful
Noise when ge washer put in spin mode
this could be one of two problems.
The first which is fairly cheap to repair would be to check the carbon brushes in the motor, they may need replacing, especially if your washing comes out wetter then it should.
The second is the bearings on the drum which is more expensive to replace and would need to be done by an engineer.
1helpful
2answers
Remove the front lower panel (3 screws on lower lip - lay on floor to see). Panel come right off. there is a round "dial" to the front housing. Put down a bath towel on the floor and unscrew dial - then pull it out.
GE Front Load washer problem
replace the water inlet valve it is seeping water through the valve even though the cycle has finished
1helpful
2answers
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
8helpful
2answers
GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
