Vizio E500i-B1 50-Inch 1080p Smart LED HDTV Logo
Mel Kahle Posted on Jan 28, 2016
My Vizio tv made a popping sound and shut off. Now the TV's corner light turns on when you press the power button, but the tv stays off. How do I fix it?
1 Related Answer
symte
Clive Christie
  • 26 Answers
  • Posted on Jan 28, 2016
SOURCE: My Vizio tv made a popping sound and shut off. Now the TV's corner light turns on when you press the power button, but the tv stays off. How do I fix it?
change the power supply you can find it on ebay
Greenbrier International 110064 Universal 6 In 1 Remote code to program a Vizio tv
To program a Vizio TV with the Greenbrier International 110064 Universal 6 In 1 Remote, you can follow these steps:
  1. Turn on your Vizio TV.
  2. Press and hold the "Code" button on the remote until the LED light stays on.
  3. Use the number buttons on the remote to enter the code "11864" for Vizio TVs.
  4. Press the "Power" button on the remote to see if the TV turns off. If it does, press the "Enter" button to save the code. If it doesn't, repeat step 3 with a different code from the list below until you find one that works.
Other possible Vizio TV codes for the Greenbrier International 110064 Universal 6 In 1 Remote include:
  • 11758
  • 11756
  • 11742
  • 11740
  • 11738
  • 11687
  • 11670
  • 11587
  • 11365
  • 11136
Note: If you can't find a code that works for your Vizio TV, you can try the auto-search function on the remote. To do this, follow steps 1 and 2 above, then press the "Power" button repeatedly while pointing the remote at the TV until the TV turns off. Once it does, press the "Enter" button to save the code.
2answers
My Vizio tv will not turn on. The white light in the lower left corner lights but no illuminated screen appears.
Power cycling can solve a lot of odd problems with Vizio TVs. First disconnect the TV's power cord from the power outlet and leave it unplugged. Then press and hold the power button on the TV for 10 seconds. After you have held the button for 10 seconds, let go then try to power the TV on.
1helpful
Need remote code for Vizio D32h-CO. No remote for TV. Have Dish remote
For my universal remote control's manual, all of the VIZIO codes are:
11758
13758
12757
Also, remember that you can have the remote scan for codes on its own. On the remote just hold the "TV" control button (should be at the top near the power button) and the power button turns on. Then hold the power button too, and it shuts back off; keep holding until it turns back on and then it will stay on. Then, point the remote at the TV (it should be on) and press the power button every three seconds. It will test a code every two or three seconds. When your TV finally shuts itself off in response, you've got the right code and the remote should work.
Resetting without going to the menu for a vizio m220nv
Get into the Vizio TV service mode
There are to options to get into Service mode:
Option 1:
Turn the Vizio TV off.
Press and hold the CH + & CH - buttons on the TV.
Then press and release the POWER button on the TV Vizio.
Release the CH+ & CH- buttons.
Now press the MENU button on the remote.
You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This if for factory reset).
Press and hold the MENU button for few seconds.
The Service Menu will be displayed.
Option 2:
Turn off th Vizio TV.
Press and hold the CH+ & CH- buttons on the TV Vizio.
Then press and hold the POWER button on the TV.
Keep all three buttons pressed for few seconds.
Calibration settings for this set video
Vizio Service Menu Method 1
1.Turn The TV off.
2.Press and hold the {CH +} & {CH -} buttons on the TV.
3.Then press and release the {POWER} button on the TV.
4.Release the {CH +} & {CH -} buttons.
5.Now press the {MENU} button on the remote.
6.You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
7.Press and hold the {MENU} button for few seconds.
8.The Service Menu will be displayed.
Vizio Service Menu Method 2
1.Turn The TV off.
3.Then press and hold the {POWER} button on the TV.
4.Keep all three buttons pressed for few seconds.
Vizio Service Menu Method 3
1.Press and hold the {EXIT} button on the remote for 3 seconds then release it.
2.Then press the {1} {2} {3} buttons on the remote.
3.To exit, press the {EXIT} button.
4helpful
Vizio GV47LFHDTV10A No Video No Sound after "POP"!
change the main board first. if you're lucky this will fix the problem if not your inverter is dead.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
