Samsung Galaxy Tab 3 Lite SM-T110 8 GB Tablet - 7" - Marvell ARMADA PXA986 1.20 GHz - White 1 GB RAM - Android 4.2 Jelly Bean - Slate - 1024 x 600 Multi-touch Screen Display - Bluetooth Logo
dean Poston Posted on Jan 27, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I accidentally deleted Google Play service now I can't seem to get it back how do I do that
L Pfaff
Level 3:
Top Expert:
  • Samsung Master 11,573 Answers
  • Posted on Jan 27, 2016
L Pfaff
Samsung Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3585190
Points
181713
Press the helpful button and follow me on Fixya for more good tips
Re install google app or service
How to install Google Play Store app manually
How To Intsall Google Play Store On Any Android Tablets Like HCL Me Tablet
My lenovo tablet won't let me open setting because I get message saying unfortunately google play has stopped working, does any one how to fix this problem? Can any one help
Google Play Services, the preinstalled app on your phone plays an extremely crucial role in the regular running of your lenvono. If anything is wrong with it, then your lenovo will start throwing fits in the form of errors and crashes including 'Google Play Services keeps stopping' error.
To remove the error, you need to fix Play Services. Here you will find numerous ways to fix any issue related to Play Services. Let's get to know them.
1 Starting with, will actually with restarting you Lenovo.
2 Another that does wonders for any issue is to "clear the cache" and date of the particular app. In this case, we need to clear cache and data for "Google Play Services" and "Google Play Store".
Doing any of that will not delete any data from your phone. However, clearing data will log you out from Play Store and reset its settings. In settings
3 "Google Play Services" is a system app, you cannot remove it from your lenovo completely. However, you can uninstall the updates, which will revert it to the factory version forcing your phone to update it automatically, thus fixing any issue.
On the Google Play Services screen, tap on the "three-dot" icon at the top-right corner. Select Uninstall updates from the menu.
4 Unlike other installed apps, you don't have to update Google Play Services manually. It's done automatically in the background by your lenovo.
However, sometimes, the issue is with the update itself. So you need to update it to the newer or older version manually. We have covered ots of ways to update google play service in detail. Do check that. And if you face any issue while updating it, check fixes.
6 Similar to restart, sometimes booting in the safe mode fixes various issues on an Android phone. Again, doing that will not delete you data and you can access it in safe mode as well. Running the lenovo in safe mode also helps in identifying the issues caused by the third-party apps.
I hope these will get you over your issue with ease.
I have lost my app for Google how can I get it back
Isobel, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Reinstall and re enable apps
How to Recover Deleted Apps on Android Phone or Tablet
How to Restore Google Play Store if You Accidentally Remove It
2answers
My google play google service was deleted by mistake. Can I get it back on my tablet?
You can reset the tablet to factory settings by going to settings and starting over.
1helpful
The Google play services are not working on my Tablet, how can I fix this?
Google Play Services needs to be updated from time to time. It seems to keep getting bigger and bigger. You can go into Settings - Apps and then ALL and scroll to find Google Play Services and then click on it. The screen that comes up will give you the option to clear the cache and clear the data.
First clear the cache. Then see if that solves the problem. Likely it won't. Then you can clear the data. It that doesn't work for you then click on *uninstall updates.* This will reset the Google Play Services to original factory. Reboot and make sure you have a good wi-fi connection as the Google Play Services should connect to the Google Play Store and update automatically. If it doesn't, then open the Store app and select *My Apps* *All* and scroll to Google Play Services.and click *Update*.
Note: the Store App, itself, might be slow and balky until the updated Play Services is installed and running.
Here's a hint. If you do the above and delete the updates from the Google Play Services app on your device, when you boot up your device might act balky - just give it a few minutes as it's probably connecting and downloading the Google Play Services updates automatically. Google Play Services is important for just about everything that communicates with Google so don't expect all the other Google apps to work until the updated version of Google Play Services is installed and working.
2helpful
2answers
Why do my Google play services are not available on my tablet?
1. Remove the updates for your Google Play
- Go to the menu->settings->apps->all->google play store-> uninstall updates, then reboot your device.
2. Remove the cache for your Google Play
- Go to the menu->settings->apps->all->google play store-> remove cache, then try to run your google play again. It is better to do a reboot.
3. Try to delete and re-install Google Play
- In some cases, delete and re-install resolve this issue.
4. Try to delete your google account and add your google account again
- Go to the menu -> settings -> account remove your current google account then add it again here.
1helpful
How do i reinstall Google play services on my tablet? Google has stopped working..
Follow the directions here: http://www.androidauthority.com/how-to-install-google-play-store-312812/
How can I delete a Google play book?
Contact Google on how to delete books.
1helpful
When I try to download an App, I get an ERROR that says: Error retrieving information from server. [RPC-S-5:AEC-0]. How can I get this to download apps?
Fixing RPC:S-5:AEC-0 Google Play Store Error
The Google Play / Android Market error retrieving information from server RPC:S-5:AEC-0 error message can be a bit of a pain, the RPC:S-5:AEC-0 error just randomly appeared on my tablet after it upgraded to a newer version of Android. However this is how i managed to fix the RPC:S-5:AEC-0 error with ease.
  1. Load the Settings app, click apps, then select "All"
  2. Next in the all apps view find the "Google Play Store" and click on it
  3. Now click "Clear Cache" (Not Data), then Force Stop.
  4. Next in the same app list find "Google Service Framework"
  5. Click clear data (Not Cache), then Force Stop
  6. Switch off the phone or tablet and turn it back on
  7. You should be able to download and update apps from the Google Play store once more.
Enjoy no more RPC:S-5:AEC-0 errors when downloading or updating apps.
Or Simply Go to settings/app.manager/all
Delete data + cache :
Google Play Store
Google Play-services
Google Services Framework
Hangouts
Market-feedback agent (important)
Then delete google-account(data/system/user/0/ fine the accounts.db file and cut and paste it somewhere else)
Restart the phone and then re-add google-account( paste your accounts.db file earlier to it's original location).
p/s~Your device need to be rooted to remove/delete google account without a factory reset.
enjoy and have a good day :)
Top Samsung Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
