Icbm 779 i just recently changed my subs out and put two mtx 4500's and when i changed them out my bass wasnt the same.. i tried messing with the settings but it's still sounds messed up.. i was wondering if you knew the factory settings that the amp comes with ..
If there is significantly less bass even though the speakers are moving approximately the same as before, you may have one speaker wired out of phase. Disconnect one speaker. If the bass increases, double-check your wiring.
if you turn the bass setting in your radio down it will take the bass out, but may take some of the bass out of the subs as well, if this occurs and you still are not satified, you either have to get a car receiver with a non fading subwoofer preout, or you could get bass blockers for all the speakers you dont want the bass in
turn down music open sub box and put another speaker at wire and check again if work means sub is ok if not check the signal cable, and put there the speaker to try signal
there are several ways, it all depends on the bass response you want, and with that, it also changes the ohms in the amp. i'm going to give you seval ways to hook them up. if you are running more than one just follow these steps per sub. the first one is if your sub is dual 2 ohm.
Wiring Option #2
Wiring Option #2
this is for dual 4 ohm coils Wiring Option #2
Is there a option on the chanels that say ''Bridged''? If so, you can hook the subs up in parellel or series to get different ohm loads. Usually the lower ohms, the more power amp puts out. Those subs can handle 225 watts RMS whitch means the power it can handle constantly. If the amp gives more than 225 watts RMs, you could be at risk of blowing the sub. If you could give me the model # of the amp, I can be of more help.
I Had the Same Problem I just unplugged my amplifier changed the fuse, also i had a fuse in the battery cable and changed that, unconnected the RCA wires and plugged them back in and then put new fuses in and plugged everything back into the amplifier and it worked again. If that doesnt work get back to me i will try to help you.
Well it could be that your ears just got used to the bass. It happend to me after about a week of haveing my subs. And make sure that your power wire hasnt got melted somewhere. also that you have good ground.
You may have a defective speaker or a wiring fault. Disconnect the speaker from the amp and measure the resistance across the speaker wires. The resistance should be near the rated impedance of the speaker.
the remote of amp. is not a ground it is a pos.+ 12 vlts look the back of your car stereo red the remote and conect to remote of the amp. if no sign remote of the car stereo conect to the 12 vlts of your bat.
hi, first disconnect the rca input, then switch on headunit and if the amp produces a constant bass thump it then means it has an internal fault. if the amp idles quietly then replace the rca cable, or try connecting the headunit lineout feed directly to the bass amp, in this way you cud find out if your fault is coming from the headunit or the equaliser. cheers
