SOURCE: Sunbeam Stand Mixer
For whatever reason, Sunbeam must have decided to cut on costs and used a plastic gear to transfer power to the beater. I had my Sunbeam for two years and the plastic gear decided to break. End of mixer. You cannot find a replacement part anywhere. It is the last sunbeam I will buy.
SOURCE: sunbeam mixer
When you open it, there is are contact points and a piece that has to touch to change the speed. It may just be slightly bent or out of place. Some food may have gotten in there.
SOURCE: Model #2366 mixer blade release problem
I found a site that says it has replacement stands for 19.95 plus shipping. You can check it out at http://www.bettervac.com/proddetail.asp?prod=SUN%2D84128&cat=293.
Good Luck
Dan
SOURCE: Regarding the Sunbeam Mixmaster (model
Pry the beater release button out with a screwdriver. There are two screws underneath it and one under the motor housing between the the beater holes. This will allow you to remove the chrome front cover, but not the motor and drive assembly. Getting to the part that contains the gears requires complete disassembly of the mixer. It is not designed for service, and requires patience and a variety of tools to disassemble.
It has a metal worm gear and plastic drive gears. If the beaters are out of alignment, then one or both of the plastic gears are stripped and the mixer is junk. Repair plus shipping costs equals the price of a new mixer. This is the weak point of these mixers and a fundamental flaw in an otherwise robust and sturdy design. It is definitly not the same mixer *********** bought 30 years ago.
SOURCE: have a sunbeam heritage stand mixer model 2346-000.
Make sure the bowl is off to the side. I wouldn't get rid of a mixer just because the bowl doest't, if it's a good powerful mixer. There aren't many replacement parts available except directly from sunbeam. You need to get a replacement motor for the bowl turntable.
