Made in Wichita and has a code number: A739
SOURCE: Manual for a Coleman Forced Air Furnace manual
If you haven't already tried Coleman customer support, try Google. You can find owner's manuals for all kinds of things. good luck, John
SOURCE: replacing filter on coleman furnace L8T
The bottom panel should either pop out of lift up. They can get a little stuck so you may need to use a screwdriver or similar tool. As long we''re talking about these units, see this link:
http://www.recall-warnings.com/cpsc-content-01-01523.html
Safety first!
SOURCE: water leaking from coil pan that is cracked down center
maybe you can fill the pan a little with some type of sealent, like resin, that might seal the crack pan..
SOURCE: r.v. coleman mack furnace
Try calling a local appliance repair or HVAC/refrigeration contractor.
A mechanical refrigeration contractor would have a better chance of having or being able to get replacement parts faster. But you have to get someone with an HVAC knowledge to look at it.
While the R.V. mechanics may be good at simple repairs or general knowledge, you need a trained eye to look at this issue here.
I would suggest to have a tech diagnose the problem and quote to repair. If the quote sounds reasonable, then go for it (your paying for expertise and a warranty). If not, then you at least have an idea of where the problem lies and what steps needs to take place to try to get it fixed.
RV Products
A Division of Airxcel, Inc.
P.O. Box 4020
Wichita, KS 67204
PS: If you buy things on most American Express cards, they extend the manufacturer's warranty by an additional 1 year for FREE. It's saved me hundreds of dollars over time. Other credit cards may include similar features.
